03-13-2020 15:10
03-13-2020 15:10
Hey,
So with the current coronavirus outbreak one of the simplest things that can prevent infection is to minimise/avoid touching your face unnecessarily. The IMU fitted to presumably every fitbit device should be able to roughly detect when someone is about to touch their face with the watch hand (with a series of assumptions) and in turn provide a warning (vibrate).
I understand this is not a complete solution for people touching their face, however considering how prolific fitbit hardware is it could be something that might atleast make fitbit users more aware of when they do.
I guess this would be more or less possible with fitbit devices that run fitbitos since you are able to develop custom applications that presumably have access to IMU data. I guess fir the trackers you really need to speak to someone at fitbit and convince a firmware dev that it's worth trying to roll out updated firmware.
Cheers,
Lindsay
03-13-2020 18:43
03-13-2020 18:43
The suggestion has been made here - click to view - in the Feature Suggestions area of the forum. You might want to share your post there, @linzoi
