05-03-2024 08:43 - last edited on 05-04-2024 07:49 by MarreFitbit
I dropped my Sense face down on tile (it had a screen protector on it so the face didn't break)since then the fitbit logo is flashing and won't do anything else. I have tried restarting it, I followed other instructions I have seen including removing it from the app and can't get it to do anything including re-adding it. Is it time for a new one??? Did I really break it???
05-04-2024 07:51
05-04-2024 07:51
Hi there, @newuserPam15. Thanks for stopping by in the Fitbit Community Forums and for the troubleshooting steps you've tried. I'm sorry to hear that your Sense is still stuck on the Fitbit logo is still crashing itself suddenly. I will do my best to help you with this!
As our last resort, I'd recommend performing a factory reset on your Sense. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
With the above being said, please sync your Sense and then, proceed with the steps below in the order listed:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
05-07-2024 06:24
05-07-2024 06:24
The process listed that Marre provided does work, however, it may take you several tries because the timing is quite sensitive. If you miss it by even a little bit, the Fitbit won't reboot properly. If successful, it will chime and ask you to update the software on it. This took me 4 times to get (after I bought a Sense 2) thinking my original Sense was broken for the same reason.
05-08-2024 09:22
05-08-2024 09:22
@LeaderSmall Thanks for stopping by! I'm glad to hear that the steps I recommended above did the trick for you. I appreciate you taking the time to add that clarification, I agree, timing is key to properly complete the factory reset.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
