03-21-2023 02:31 - last edited on 03-23-2023 05:20 by MarreFitbit
Can’t do screenshots, but last two days on my iPhone app a pop up message says “Bluetooth Pairing Request” Sense would like to pair with your iPhone and then a green fix it bar Pair Sense with your phone for a better connection (and a Fixit button)… anyone know why this just recently started and possible fix? Thanks!
03-23-2023 05:24 - edited 03-06-2024 09:40
Hi there, @dgreene99. Thanks for stopping by in the forums and already trying to troubleshoot the issue with your Sense.
In addition to the steps you've done so far, please try the following:
With the steps above, what I want you to do is to pair your Sense first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
If the above doesn't work, please follow @Guy_'s advice and chat with us online or give us a call. Click here to get connected.
03-23-2023 00:22
03-23-2023 00:22
Hi @dgreene99 - it would seem that Bluetooth is having a hard time which may be because you are using multiple devices with your watch [unknowingly]. If you have another phone or iPad turn off the Bluetooth on them.
Logout of the Fitbit App and swipe off the active window and restart the phone and the watch.
Login again and wait for any pair or link or fixit prompts and sync. This should resolve the problem.
Also make sure that the Fitbit App can run in background in case the phone is stopping the app, for battery savings.
03-23-2023 03:41
03-23-2023 03:41
03-23-2023 05:09
03-23-2023 05:09
@dgreene99- thanks, in that case it may require a factory reset or is just faulty.
If it gets hot when charging stop immediately as there is internal damage which can also cause short battery life.
Please post conclusion.
Fitbit are reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
03-24-2023 10:09
03-24-2023 10:09
03-24-2023 10:17 - edited 06-19-2023 06:27
@dgreene99 Awesome! I'm glad to hear that the issue is solved now.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
