キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
Is it possible to get location data of iPhone (not one of fitbit device) from companion ?
解決済み
I want to use location data in some term (ex. get location data in every 6h), but I think getting GPS data of device might consume battery. So, I want to use location data of iPhone from companion.
Are there any idea or function by fitbit?
受理解決策
0 件の賞賛
1 件の受理された解決策
受理された解決策
Understood.
However, a tracker with built-in GPS must choose to use or not use GPS.
If you choose not to use it, the track cannot be displayed on the application.
Conversely, trackers without built-in GPS are automatically set to use the mobile phone's GPS.
Therefore, current trackers with built-in GPS will not be able to plot trails without other apps.
Also, this is a Japanese forum, so I would recommend you to use the English forum.
https://community.fitbit.com/t5/Community/ct-p/EN
元の投稿で解決策を見る
受理解決策
3件の返信3
I use "Sence2".
This device has a built-in GPS.
However, the accuracy of the GPS is low, so I turn off the GPS of the device.
In case of Android OS, I can plot the training route with location information by linking the fitbit app to GoogleFit app.
In the case of iOS, if you want to plot location information, it would be better to use some other app.
受理解決策
0 件の賞賛
Thank you.
Oh, your idea needs other apps of moblile phone.
I want one without other apps...
受理解決策
0 件の賞賛
Understood.
受理解決策
