01-20-2021 15:03 - last edited on 01-21-2021 12:30 by LiliyaFitbit
My ace 2 alarm won’t work. I downloaded it and I checked my fit bit and it says it is still not downloaded.
01-21-2021 12:29
01-21-2021 12:29
Welcome to the Fitbit Community, @SimplyAce2.
Thanks for the details shared in your post. You can set and delete alarms in the Fitbit app. Turn alarms on or off directly on Ace 2 in the Alarms app. I recommend confirming the steps to set up an alarm at How do I manage alarms on my Fitbit device? Make sure to sync the Ace 2 to save the changes. You can find the steps to sync the tracker at How do I sync Ace or Ace 2 with my device?
I'll be around if you need further help.
