Ace 2 and Ace 3
Are the Ace 2 and Ace 3 the same size? Wanting to buy my daughter a new strap but can only find Ace 3 straps
2 REPLIES 2
Hello @Hoody16 and welcome to the Community.  A moderator said they aren't compatible in this thread.   Please check a site like Amazon or eBay for a third party band.
Laurie | Maryland
While the 2 devices have identical size the ACE 2 has a physical buttons while ACE 3 has capacitive buttons that require opening on both sides.
I'm quite confident ACE 3 bands can fit ACE 2 (because of the openings) but of course they don't look good.
I would suggest to check on Aliexpress , I bought some very cheap for my son's ACE 3 and they are ok. The picture below is for ACE 2.
Formerly Giampi71 - Retired from Fitbit for good on November 13th 2023
