03-11-2021 13:35 - last edited on 03-14-2021 16:40 by LiliyaFitbit
From reading through the community posts I see that this has been an issue since 2019, but thought I would see if there's been a fix yet as I just bought my daughter an ace2 (it's now 2021) and I'm having the same problem. The sleep data does not display on the watch itself, but does display in the app on my phone. My daughter really wants to see the data on her watch. Has anyone found a solution to this?
04-02-2021 08:30
04-02-2021 08:30
I may have found a fix.
While on the kids fitbit profile there's a "Discover" at the bottom center.
Go to "Fitbit Status"
Go to sleep and set up the sleep app again.
Our Ace2 started to display sleep after that. Hopefully this fixes the bedtime reminder also.
03-14-2021 16:39 - edited 03-14-2021 16:48
Welcome to the Fitbit Community, @Sarz987.
Thanks for the details shared in your post and for your efforts to resolve this. I understand how you are feeling about this situation. I recommend trying the following:
Hope this helps.
Best Answer04-02-2021 07:55
04-02-2021 07:55
I am having the same problem. Went through half of the watch faces with no change and reset the fitbit several times. No change.
Best Answer04-02-2021 08:30
04-02-2021 08:30
04-02-2021 19:40
04-02-2021 19:40
Welcome to the Fitbit Community, @TheDavidS.
I am happy to hear that you were able to fix this issue and thank you for sharing what you did as it may help other members in the same situation. I appreciate your time and efforts.
In case you have some spare time, I would like to invite you to visit our Discussions board where you can share your experiences, make new friends and create new topics.
Keep on visiting the forums!
