12-22-2020 13:07 - last edited on 12-23-2020 12:15 by LiliyaFitbit
So I received this from my mother today and have been struggling with it for half an hour. It syncs, but it won't swipe, display any data like steps, and no matter how long I hold the button it will not open the settings to even set the time and date. I have also had it on the charger the entire time and it was 40 percent when I started set up. It will turn on with the smile face but displays the www.fitbit.com/setup instead of going directly to the home page or whatever you want to call it. Help me out!!!
12-23-2020 12:13
12-23-2020 12:13
Welcome to the Fitbit Community, @EvanB2008.
I understand how you are feeling about this situation. Thank you for trying to resolve this and providing the additional details. I've shared your post with our Support team and they've mentioned that you already have a case with them. I know they will be glad to help you out and provide a solution, please keep an eye on your inbox.
I'll be around if you have any questions.
12-24-2020 08:53
12-24-2020 08:53
I have basically the same issue as this user, except that our ace 2 is fully charged. The app (windows) recognizes it and it is synced. This is the extent of what it will do. The ace 2 displays a horizontal line and when the button is pressed shows the fitbit.com/setup screen. I'm reaching out here since it seems like the customer service chat etc. is not going to have a super quick response.
thanks!
12-24-2020 10:36
12-24-2020 10:36
Welcome to the Fitbit Community, @amj0826.
Thank you for joining the thread and sharing the details of the issue with your device. I understand your concern and recommend trying the following:
Let me know how it goes.
12-24-2020 11:31
12-24-2020 11:31
Thanks for the help, unfortunately when I try to select a clock face we just get the spinning circle icon and nothing happens. Same thing when I click on the 'my apps' button.
12-24-2020 11:50
12-24-2020 11:50
Thank you for your reply, @amj0826.
I appreciate your efforts and would like to confirm if you can try changing a clock face using the Fitbit app on the mobile device? You can check the devices compatible with the Fitbit app at Which phones and tablets can I use with my Fitbit watch or tracker?
Looking forward to hearing back from you.
12-24-2020 12:50
12-24-2020 12:50
Hello,
The option to create a family account isn't available on the mobile device I initially used to set this up. That is why I switched to the windows app. Looks like this is just going to be a return. I guess I don't get why there has to be an app connected to a mobile device and all this personal data involved when my kid just wanted to count her steps. I'll do my homework more thoroughly in the future. I appreciate your help anyway.
12-25-2020 16:55
12-25-2020 16:55
I appreciate your efforts and the additional details. I understand how you are feeling and recommend trying the following:
If you don't see the option for "My Family", please uninstall and reinstall the app on your mobile device.
Keep me posted on the outcome.
12-26-2020 01:03
12-26-2020 01:03
HI
I am having the same issue as this user and I don't have the option to connect to a mobile device.
Can you explain how I can activate the fitbit and set up the clock faces using my computer- it just continues to 'death spiral' as the user above mentioned. Do I need to return my device also. I have spent about 60 minutes plus over the course of today trying and retrying to activate this device
thanks
12-26-2020 01:27
12-26-2020 01:27
Hi Joce1970 I have exactly the same problem with Ace2 bought for small person. Spent too long yesterday trying to fix. Now following the post above deleted and restarted my Fitbit app. Hardest Fitbit ever to start!
12-26-2020 16:38
12-26-2020 16:38
Hi AB060Loch,
Let me know if that works. I gave up just after my post yesterday and am about to try and troubleshoot this again today.
I think I might try the same- delete the app and see if that works. I agree- thinking this is a product designed for kids- you actually need a post-graduate degree in ICT to operate. Even my teenage kids were unable to solve the issue.
12-27-2020 02:06
12-27-2020 02:06
Hi Joce1970..yes we finally had success. I deleted & reinstalled the Fitbit App on my phone and then set up the Ace 2 account again. 5th time lucky! Hope you got yours working too.
