09-28-2022 23:44
09-28-2022 23:44
When I try and squeeze both sides of my Ace 3 when the silent alarm goes off I am only able to snooze it. I am holding both sides at the same time for 2 seconds but I see it’s always still just snoozed. My kiddo is going to be using it for a med reminder at school and this will be a real distraction.
09-29-2022 07:40
09-29-2022 07:40
Hi there @Ntibbo. Welcome to Community Forums. @SteveH thanks for the help.
I appreciate you shared your experience with your Ace 3 device. I'd recommend you check this article, How do I manage alarms on my Fitbit device?.
If you continue having the same issue, please contact our Support Team.
Hope this helps.
Best Answer09-29-2022 02:20
09-29-2022 02:20
I'm not that familiar with the Ace 3 but found this in the manual:
"When an alarm goes off, the tracker vibrates. To dismiss the alarm, press the
buttons. To snooze the alarm for 9 minutes, swipe down. "
I wonder if you need to hold the buttons for 2 seconds - perhaps a long hold is being read as a swipe? What happens when you briefly press the buttons?
09-29-2022 07:40
09-29-2022 07:40
Hope this helps.
