02-07-2022
05:47
15:30
EdsonFitbit
02-07-2022
05:47
15:30
EdsonFitbit
This is perhaps an unusual query and possibly a nice 'problem' to have. My daughter's Ace 3 (christmas present) has only needed charging once since we gave it to her - it seems to have at least three weeks of battery life. She's been wearing it every day.
The battery life is so good that I'm concerned that it may not be performing some of its functions - though it does appear to track steps and log active minutes.
The device is synced with a Kindle Fire 10 HD tablet (has Google Play installed so can use Fitbit android app) and I wonder whether it may be that this link is particularly parsimonious in terms of battery requirements for syncing.
Has anyone else found a particularly good battery life for the Ace 3 and if so have you noticed any particular deficiencies with your unit, or any conditions under which this surprisingly good battery life occurs?
All thoughts gratefully received!
Thank you.
02-07-2022 15:27
02-07-2022 15:27
Welcome to the Fitbit Community, @Raz124.
Thank you for the information provided.
The estimated battery life for the Fitbit Ace 3 is up to 8 days. The syncing process shouldn't affect the battery life.
In this case, I would recommend performing a restart to your daughter's Ace 3 by following these instructions.
Hope this helps.
Best Answer02-07-2022 15:35
02-07-2022 15:35
Best Answer02-08-2022 13:08
02-08-2022 13:08
Thanks for your response, @Raz124.
If after following the instructions shared above your Fitbit device's battery is not drained as estimated, the best way to get help for this situation is to chat with us online or give us a call. Please click here to get connected.
Have a nice day.
