12-23-2022 15:41
12-23-2022 15:41
Purchased 2 Ace 3s for kids for xmas.
Ace 3s will not connect to phone - tried two phones in house now.
Get exactly the same on both Ace 3s on both of the phones we have tried. Tried switching bluetooth on and off, and also tried rebooting both phones. Outside of the app, my phone can see the Ace3 as an 'available device' in its bluetooth list.
Can anyone help?
12-24-2022 12:33
12-24-2022 12:33
Currently having exact same issue, tried 2 phones new app install on each and device try's to connect with PIN then X sign.
One very upset child at moment, does anyone have any ideas how to fix this?
 Best Answer12-24-2022 17:20
12-24-2022 17:20
I am having the same issue with my android phone. App is up to date, but still it fails to connect. I even disconnected all the bluetooth devices connected to my phone, restarted the phone and ensured bluetooth was on, and no other devices were connected to bluetooth.
 Best Answer12-24-2022 23:17
12-24-2022 23:17
Something wrong with android app i had to resort to using and old iphone to get it setup in case this helps anyone
 Best Answer12-25-2022 00:24
12-25-2022 00:24
Same here! I don't own any iPhones so hoping there is a solution other than connecting to an iPhone
 Best Answer12-25-2022 00:31 - edited 12-25-2022 00:31
So I initially contacted Fitbit support, who after a length chat said I should return both Aces 3s...
However on a hunch I tried something else and managed to get them working - I went and found my old phone and installed the fitbit app on it. I was able to pair it with my old phone, and the first thing it did once paired was download a large software update onto the ace 3. After the software update and and the inital setup on that old phone, I repeated the setup process with my current phone, and this time it worked perfectly.
So it seems the fitbits are shipped with a buggy software version on them, so if you can find some another phone to get it updated initially, do that then try again on the phone you actually want to use it with.
12-25-2022 01:54
12-25-2022 01:54
No other phone here. Also Sat on chat for way too long and they advised to send it back. I mentioned others were having the same issue so they've 'escalated' it, whatever that means
 Best Answer12-27-2022 07:57
12-27-2022 07:57
Was this other phone an iPhone? I only have android phones, same issue. Tried 2 android phones and they don't work.
 Best Answer12-27-2022 08:55
12-27-2022 08:55
I re-booted my android and finally got it to work. 1 watch down, 1 to go.
 Best Answer12-29-2022 09:18
12-29-2022 09:18
This was it! Thanks. Borrowed an older android phone from an in-law. Connected the watch to that phone and the phone instantly did a firmware update. Straight after that I was able to connect it to my more modern and updated phone. So it seems to be the firmware on the watch. Thanks for the help, this was driving me mad!
 Best Answer07-05-2023 21:29
07-05-2023 21:29
I changed my android internet from wifi to mobile data
