Ace display won't turn on
Hi,
My Fitbit Ace device has full charged. But if unplug power cable then having an display issue once it went to sleep mode. It does not display anything except black screen. if plugin power cable then it will display screen properly. I restarted couple of times but no luck.
2 REPLIES 2
if it's not sleep after unplugging power then it is going to display till to sleep. Once it goes to sleep then it never display till again connect to power cable. Is there any way to change sleep settings.
Welcome to the Fitbit Community, @Lokesh.Y.
Thanks for the details shared in your post and for already trying to resolve the issue. I've shared your post with our Support team and they've mentioned that you already have a case with them. I know they will be glad to help you out and provide a solution, please keep an eye on your inbox.
See you around.
