06-28-2019 21:10
06-28-2019 21:10
Done a reset 3 or 4 times but the screen is still dim for some reason. It's a bit hard to see during the day for my daughter, dim is good at night...but she doesn't look at it while she sleeps!
..any ideas?
04-08-2023 00:38
04-08-2023 00:38
I’m unsure whether the best answer should be the first steps tried.
There is a “Dim” setting if you scroll up on the watch face (not in the Fitbit app). Try setting that to OFF (I believe it’s on by default).
06-29-2019 04:41
06-29-2019 04:41
@Milan_k welcome to our Fitbit Community! I'm happy to assist you with your daughter's Fitbit Ace since the screen is still dim even though you have restarted it before contacting our forums.
Please have the Fitbit Ace battery to drain completely. After this, charge the tracker for 2-3 hours and restart it one more time. Finally, check out if the screen gets fixed.
Keep me posted on the outcome!
06-29-2019 05:26
06-29-2019 05:26
Thanks for the tip, will run it down and re charge to see what happens
07-01-2019 05:29
07-01-2019 05:29
@Milan_k thank you for your time and trying the tips above.
Don't hesitate to get back if you have any questions in the meantime!
04-08-2023 00:38
04-08-2023 00:38
07-23-2023 10:18
07-23-2023 10:18
I am having the same problem. I bought two Ace threes at the same time. One for each of my children. The one for my son is fine there's no problems with it the screen is bright and easy to read. The one I bought for my daughter is very dim and next to impossible to read outside in the sun. Even inside in a dimly lit room it's hard to see. I've tried adjusting the dim screen setting to off and it seems to make no difference. I contacted support and they basically told me there was nothing they could do and it was out of warranty. I gave them the watches for Christmas in 2021 and my daughter rarely wears hers. Seems to me it's faulty hardware and that other people are having the same problems but Fitbit does not want to recognize that.
