01-23-2020 13:02 - last edited on 01-24-2020 16:29 by LiliyaFitbit
Recently my Fitbit Ace kept powering off and i was unable to turn it on my tapping it. When i charge it the fitbit logo came on and it says the battery isnt flat. Now i previously emailed fitbit about this and they sent me a free replacement but the only problem is that the new one is having the same problems as well! As soon as i take it off charge it powers off unable to be turned on again but when i charge it, it says the battery isnt flat again. I have tried uninstalling and installing the fitbit app, used my friend's fitbit charger and created a new account altogether. I have also tried pressing the button on the cable three times to no avail. Nothing I try helps, please can you reply.
01-24-2020 16:26
01-24-2020 16:26
Welcome to the Fitbit Community, @SunsetRunner.
I appreciate your participation in the Forums and sharing the details of the issue you're experiencing with your replacement Fitbit Ace which keeps turning off. I totally understand how you are feeling and appreciate your troubleshooting efforts including a restart. Since the issue persists, I've sent your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Let me know if you have any questions.
02-15-2020 15:18
02-15-2020 15:18
I'm having the same issue with my daughters Ace. I've tried everything that i could find. what's the fix?
02-16-2020 11:00
02-16-2020 11:00
Welcome to the Fitbit Community, @Rafi324.
Thank you for joining the thread and sharing that you're experiencing the same issue with your daughter's Ace. I appreciate your troubleshooting efforts. I would like to confirm if you've tried to change the clock face and if you see anything when you connect the tracker to the charger?
Please keep me posted, I'll be around.
02-16-2020 12:22
02-16-2020 12:22
Yes I have. The same issue happens with any of the clock faces. I’ve tried every fix that I found.
02-16-2020 15:16
02-16-2020 15:16
Hi @Rafi324, thank you for your response.
I appreciate your efforts to resolve this issue. Since the steps you tried didn't work, I've sent your information to the Customer Support team so they can get in touch with you and provide further assistance. You should be getting a reply soon.
06-02-2020 02:01
06-02-2020 02:01
What was the outcome of your problem - I am having the same problemwith my daughters Ace and received replacement and its doing exactly the same thing
06-02-2020 02:06
06-02-2020 02:06
I emailed Fitbit again and they sent me another replacement, this one works and I have had no problems with it to this day. it's just spooky that both of them had the same problem
06-04-2020 22:04
06-04-2020 22:04
The same thing is happening to my daughter ace. We have had it in the charger, tried different outlets but it will not do anything. It doesnt turn on at all. Not even a light to show it is charging??? 🤔 we havent had it long it was a bday present for my daughter. We have had it for about 2 months.
07-05-2020 16:43
07-05-2020 16:43
having the same issue with my daughters ace. Is there a solution? we have restarted it several times. She will fully charge it and then it works for a day or so and then just shuts off even when the app shows an almost full battery.
07-08-2020 06:09
07-08-2020 06:09
I have the exact same issue. I tried cleaning the contacts, changing the clock face, turning off alarms. It says the battery is full, but it turns off within an hour...
