08-25-2019
12:01
06:57
AlvaroFitbit
08-25-2019
12:01
06:57
AlvaroFitbit
Can’t change my sons Ace2 to 12 hour display. Have tried all suggestions posted here e.g. change my profile to 12 hour, restart the Ace2, delete and re install the Ace2. Please help.
Best Answer12-06-2020 07:59
12-06-2020 07:59
There has been a feature request created for this functionality. Everyone should go vote for it here and hopefully Fitbit will take notice if it gets enough votes.
08-25-2019 12:54
08-25-2019 12:54
Hi @niamh0606
You'll need to log in the dashboard on the website to do it. Here is a copy and paste of the directions.
How do I change to a 12 or 24 hour clock?
Let us know how that goes for you. Glad you and your son are with us!
08-25-2019 13:12
08-25-2019 13:12
Thanks for getting back to me that setting is already at 12 hour see attached/below
Best Answer08-25-2019 13:39
08-25-2019 13:39
Press submit and sync yet?
13:55
07:04
AlvaroFitbit
08-25-2019
13:55
07:04
AlvaroFitbit
Yes, no change still 24 hour format on Ace2 although 12 hour on my own Charge 2.
Sent from my iPhone
08-25-2019
19:18
06:58
AlvaroFitbit
08-25-2019
19:18
06:58
AlvaroFitbit
I notified a moderator about this, @niamh0606 and they will be by to help you with this issue.
07:08
11:00
08-26-2019
07:08
11:00
@niamh0606 Welcome to the Fitbit Community! It's great to have you here!
Let me help you changing the time format on the Ace 2 and thank you for following @Odyssey13 suggestions. This could be a clock face limitation. Could you try a different clock face and see if the format is shown there.
Let me know how it goes.
08-26-2019 07:11
08-26-2019 07:11
08-26-2019 13:38
08-26-2019 13:38
I seem to have the same issue. Nothing I’ve done seems to have helped.
11-24-2019 06:16
11-24-2019 06:16
Does anybody know if there is a solution yet? My daughter has a fitbit Ace 2 and she wants to have a 24 hour clock. I have been trying to change it, but nothing seems to work.
12-16-2019 19:12
12-16-2019 19:12
I’m having the same issue. I’ve tried everything and deleted his account and created a new one. Please help my 7 yr old is so disappointed as he doesn’t understand the 24 hour format
12-25-2019 06:45
12-25-2019 06:45
I have seen several threads with this same issue and no one seems to have fixed it. My versa is on a 12 hour setting, always has been. Just got an ace 2 for my son and it’s automatically on a 24 hour clock. I tried different watch faces, doesn’t make a difference. I can’t see any way to solve this. Quite honestly, I’m fed up with this and other problems with Fitbit, which never seem to be resolved.
Best Answer12-25-2019 06:46
12-25-2019 06:46
You. Ant do this for the ace 2, only for the parent account. And changing the parent account makes no difference, the child account is still on 24 hours.
Best Answer12-26-2019 05:36
12-26-2019 05:36
Just got a Fitbit Ace 2 . It defaulted to the 24hr time dispaly format, and I can't get it to the 12 hr format.
I have changed the default clock display setting to 12 hr on the acount on the attached device and on my PC, I have submitted it, and I have synced it, and I have even restarted the tracker, but the tracker still has the 24hr format.
How can I change it?
Best Answer12-26-2019 10:50
12-26-2019 10:50
Best Answer12-26-2019 15:08
12-26-2019 15:08
I’m having the same problem! Any solution?
Best Answer12-26-2019 23:07
12-26-2019 23:07
12-27-2019 14:15
12-27-2019 14:15
My sons was working with 24 hour clock yesterday but today has changed and is 12 hours behind. I can’t change it to the correct 24 hour or 12 hour clock.
Best Answer12-27-2019 14:45
12-27-2019 14:45
Best Answer12-27-2019 22:22
12-27-2019 22:22
I have tried that, it does not work.
