08-14-2018
12:36
11:48
FerdinandFitbit
08-14-2018
12:36
11:48
FerdinandFitbit
Daughters Ace does not last for week even after full charge. Restart hasn’t resolved issue
jow can I take back to factory settings
and start again? Fitbit does not have button in it
Moderator edit: Updated title for clarity
Best Answer08-14-2018 12:45
08-14-2018 12:45
Hi @Sangita67
There is no factory reset on the Ace. You could restart from the beginning, with a new email address and account, but any history would be deleted.
The information on the sales page for the Ace says the battery lasts five days, so what's going on with your daughter's device?
Let us know.
08-14-2018 14:29
08-14-2018 14:29
11:47
06:03
08-15-2018
11:47
06:03
Hi there @Sangita67, good to see you in the Forums! 🙂
I'm very sorry about this and thanks for what you've tried to get the Ace to work as it should.
I've gone ahead and escalated your case to the Support Team for them to take a deeper look and help you out. Please, keep an eye on your inbox for more instructions and if you need anything else, I'm here to help!
09-19-2018 17:24
09-19-2018 17:24
I believe we are having the same problem - usually at least once a day, my daughter’s Ace freezes, will not respond to touch, and has to be reset by plugging into the charger. Thoughts?
Best Answer09-22-2018 10:29
09-22-2018 10:29
@JudsonP wrote:I believe we are having the same problem - usually at least once a day, my daughter’s Ace freezes, will not respond to touch, and has to be reset by plugging into the charger. Thoughts?
It looks like you may need to contact Support as well.
one cruise ship at a time!10-05-2018 05:32
10-05-2018 05:32
@JudsonP Thank you for joining us in this thread and our Fitbit Community! I'm sorry to hear that your daughter's Ace battery is not lasting as long as it should. Thank you for trying to fix this issue before contacting the forums. I would like you to try cleaning the contacts of the Ace and charger with a cotton swab in order to remove any dust that the tracker accumulates. After this, charge the Ace completely and see if the issue gets resolved.
@DramaQueenDiva Thank you for your help my friend!
See you all later! ![]()
