06-09-2018 16:59
06-09-2018 16:59
My daughter got her Ace yesterday. We got it all set up and it was fine. Today the dreaded empty battery symbol with an exclamation point is showing on her Fitbit screen and it won’t do anything. After google searches everything is saying to push buttons to reset, but Ace has no buttons.
I’d love some help!
Thank you!
11-17-2019 14:19
11-17-2019 14:19
Welcome to the Fitbit Community, @PJ672. I am sorry for the delayed response.
I appreciate your participation in the Forums and sharing the details of the issue with your son's Fitbit Ace and the troubleshooting steps you've tried. Thank you for your time and efforts. I understand how frustrating this is for you. I've sent your information to the Customer Support team so they can get in touch with you and provide further assistance. You should be getting a reply soon.
If you have any questions, feel free to let me know.
12-05-2019 20:42
12-05-2019 20:42
Hello, I am having the same problem. I have tried all the fixes. It began that my son's fitbit wouldn't sync anymore, and I tried to reset it and that didn't work. I tried many days in a row. Then, the fitbit ran out of battery again, and when I recharged it, it had the battery with exclamation point, and nothing will reset it. I'd really appreciate being contacted by customer support as well.
Thank you
12-06-2019 02:51
12-06-2019 02:51
Hi there, I have the same problem, with my sons Fitbit ace, battery symbol with exclamation mark. Can you refer my issue to customer support person as well please. His Fitbit is only 4 months old, and now he thinks he has wasted the pocket money he saved to buy it. Thanks Murray
12-07-2019 20:43
12-07-2019 20:43
12-08-2019 14:41
12-08-2019 14:41
12-08-2019 15:04
12-08-2019 15:04
12-10-2019 20:13
12-10-2019 20:13
Same issue here and contacted Fit not rep then conversation screen went black so still without a fit bit or any help!
12-21-2019 15:29
12-21-2019 15:29
Hi, it seems we're now having the same issue. Ace was bought August and gifted/used October 19th. Had worked well until this week when battery died and since we've had the exclamation mark. We have charged from different points, reset as per this thread and cleaned charging pins with alcohol :- still nothing.
Any further advice?
01-26-2020 19:40
01-26-2020 19:40
Help! I have tried this, resetting it, and using a different wall charger to plug into. Nothing seems to be working?? I still keep getting an exclamation mark!
02-05-2020 21:56
02-05-2020 21:56
Hi, im having the same problems with my daughters fitbit. Any help would be greatly appreciated
02-10-2020 02:13
02-10-2020 02:13
My Fitbit Ace has the dreaded exclamation mark of death. Have been through the forums and tried all the suggested solutions. Could customer support please get in touch.
02-21-2020 02:00
02-21-2020 02:00
hmmm I don't know maybe the battery picture showing that it dosnt have any charge in the battery means that you need to charge the fit bit, idk it's just I guess.
02-21-2020 02:20
02-21-2020 02:20
04-21-2020 10:44
04-21-2020 10:44
My sons is doing this and I have tried all the mentioned suggestions and nothing is helping.
04-27-2020 15:53
04-27-2020 15:53
I'm having the EXACT same problem with my daughters Ace. I updated the firmware last Friday and then this started the next time it died. I've done all the usual steps multiple times.
05-14-2020 13:31
05-14-2020 13:31
My son got his Fitbit Ace last August for his birthday. We have just started having these problems with the charging etc.
We had a black screen yesterday morning and just couldn’t get the fit bit to come on. Eventually after doing numerous resets and giving it a good charge it did come back to life. It showed 100% battery. My son wore it the rest of yesterday but when he got up this morning the screen was black.
The charge usually lasts 5 days.
I’ve plugged it back into charge but just get the explanation mark and cannot get it to come on. I’ve tried the resets but it just goes back off!
Not sure what to do; thought it would have lasted longer than 9 months.
