Fitbit Ace maximum days bette en synch?
ANSWERED
Hi,
we baught 2 fitbit ACE for our kids and they are synched on they’re iPads.
ho many days can a fitbit ACE keep the information in memory before requiring a synch ? They don’t use they’re iPads during the week so can they go 7 days without synch ?
What is the maximum days to have all the informations ? They sleep with they’re ACE.
thanks
1 BEST ANSWER
Accepted Solutions
The only guidelines from fitbit I could find say:
  • Most trackers store up to 7 days of detailed minute-by-minute data. If you have a Fitbit Alta™, your minute-to-minute data is stored for up to 5 days. If you wait longer than 7 days (5 days for Alta) before syncing, you may only see the most recent week's detailed data.
  • Summary data (calories, distance, steps, and floors) will be stored for 30 days. If your tracker measures heart rate, summary heart rate data will be stored as well.
(taken from: https://help.fitbit.com/articles/en_US/Help_article/1374/ )
As the Ace is based on the Alta it looks like it can only hold up to 5 days of detailed data between syncs but if you wait longer than that then it doesn't just delete the data, it just holds it at a summary level which may be good enough for you and your kids.
1 REPLY 1
