09-06-2019
04:55
04:40
JuanJoFitbit
09-06-2019
04:55
04:40
JuanJoFitbit
I know this question has been asked before but has there been a solution to the above problem? Have tried numerous devices but all get stuck when entering the 4 digit number it then says 'There was a problem communicating with your tracker. Please try again'
Its driving me nuts!
Moderator edit: format
09-07-2019 04:40
09-07-2019 04:40
@RFletch welcome to our Fitbit Community! I'm happy to assist you with the setup process that you are experiencing with your Fitbit Ace when you enter the 4 digit number.
Please let me know what is the brand and model of the device you are trying the setup process with.
In the meantime, make sure that you are following the setup process as described in this help article.
Looking forward to your response! 😀
Best Answer09-07-2019 18:46
09-07-2019 18:46
Hi JuanJo
I had followed every step in the links you provided and nothing worked. Today it won't even find the fitbit whilst searching for it.... I have turned the fitbit off/on, deleted the app off my phone and readded, tried using our home wi-fi and also turning it off to use my own data and nothing.....
Best Answer09-09-2019 05:20
09-09-2019 05:20
@RFletch I'm sorry for the late response. However, regarding the setup issue that your Ace is experiencing, I was able to get in touch with our Support team and was told that they replied to your email recently.
Please check out your email account and reply if more assistance is needed. They'll be happy to assist you.
I'll be around if any question arises! 😀
