03-04-2019
13:08
03:27
JuanJoFitbit
03-04-2019
13:08
03:27
JuanJoFitbit
Hi, my daughters fitbit is not responding when tapped (the battery is completely charged). When attached to the charging port it will only briefly show the fitbit logo and then the v.37.01.01 message before turning off again. Thank you!
03-05-2019 03:26
03-05-2019 03:26
@kemblewaters Welcome to our Fitbit Community! I'm sorry to hear that your daughter's Ace is not responding to taps.
In order to fix this issue, please restart it as described in this help article. This will refresh your tracker internally. Once you've done this, charge the Ace for 2-3 hours and see if it turns on when you remove it from the charger.
Keep me posted on the outcome! ![]()
03-05-2019 05:25
03-05-2019 05:25
03-05-2019
09:27
06:10
JuanJoFitbit
03-05-2019
09:27
06:10
JuanJoFitbit
Excuse me, how do you know when Fitbit is charged? I don't have any body to talk to about this please tell me what to do after I connect it to computer? Is there a telephone # that I could call & get help from someone?
Moderator edit: format
Best Answer03-09-2019 06:07
03-09-2019 06:07
@kemblewaters Thank you for getting back! Since the issue persists, let me forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
@2007HOME Welcome to our Fitbit forums! I'm sorry for the late response. However, regarding your question, after you charge the Ace for 2 hours, please tap the display and you will see the battery level in the battery icon. You can also sync the device and see the battery level on the app.
Regarding your question about the telephone number, please visit this page.
Let me know if you have additional questions!
Best Answer03-12-2019 06:20
03-12-2019 06:20
Hi, unfortunately this didn’t help - I will talk to customer service. Thank you
Best Answer03-13-2019 07:27
03-13-2019 07:27
@kemblewaters Since the issue persists, I forwarded your case to our team again and they'll be in touch with you via email soon.
I'll be around if you have more questions.
Best Answer03-04-2020 12:38
03-04-2020 12:38
I am having this same issue also, please advise.
Best Answer03-05-2020 17:41
03-05-2020 17:41
What was the solution to your problem? My sons ace is doing the same thing and I followed the advice this thread gave, but no luck
Best Answer03-05-2020 21:13
03-05-2020 21:13
14:42
04:17
JuanJoFitbit
04-22-2020
14:42
04:17
JuanJoFitbit
Hi my daughters fitbit ace is doing the same thing, (tap the sxreen andnothing shows)i have restarted and re charged with no result, i have had continued issues with this fitbit, including charge not lasting, tried comments from the community board with little luck. Iit is only 15months ild ots not very good. Please help.
Im having the same issue, i have added this to forum with no response, this fitbit has had nothing but issues please help
Moderator edit: merged reply
Best Answer07-30-2020 04:17
07-30-2020 04:17
We have the same problem, the Fitbit has been purchased in December.
we have reset it as per advice but this didn’t solve the problem.
Any advice please?
thank you.
Best Answer11-20-2020 06:02
11-20-2020 06:02
Contacted Fitbit about my daughters Ace and they advised to try to reboot as mentioned above... didn’t work. They then advised that they would look into it and to watch my email. They sent me an email saying her warranty had expired so there was nothing they could do, but gave me a promo code for my next Fitbit purchase.
Best Answer04-23-2021 00:06
04-23-2021 00:06
Hi there - there I have exactly the same issue with my son’s Fitbit (I got my other son one at the same time and it works fine). Could you put me in touch with support so I can arrange a fix or a replacement please? Thanks!
04-23-2021 17:33
04-23-2021 17:33
Welcome to the Fitbit Community, @Macka7.
Thank you for joining the thread and sharing that you're experiencing the same issue with your son's tracker. I appreciate your efforts and recommend restarting the tracker: How do I restart my Fitbit device? If the issue persists, you can get in touch with our Support team so they can evaluate the tracker's behavior and help you with this matter. Click here to get connected with them via chat or phone.
Hope this helps.
Best Answer10-06-2021 03:19
10-06-2021 03:19
Our Ace has been accepted as faulty by fit bit team. An a discount was offered off any new tracker as replacement couldn’t be made.
so I have purchased a new Fitbit inspire 2, paid full price as the code wasn’t accepted despite the message “promo success”, I took a screen shot and contacted the team they said the discount will be applied, IT wasn’t! Then I have been told to send it back and the refund will be made, so I did.
Now, going through the process again. I have asked for a new code as clearly this one doesn’t work as a full price is shown. Today, I have received a message to purchase a full price item and then the fit bit team manually process the discount. No thank you!!!
Over 40 emails later this still has not been sorted. I don’t feel like having another Fitbit full stop. You have locked me in to purchase another device offering a discount code, but so far this is nothing but bad taste and I will make sure to share my experience.
Best Answer10-06-2021 09:07
10-06-2021 09:07
It’s good to see you in the community, @AngelikaNJ.
I appreciate your participation in the Forums and sharing your experience. I am sorry to hear about the frustration this situation has caused. Thank you for your feedback, our team is always working on improving our devices and user experiences, and your comments are always welcome. I would encourage you to keep working with our Support team as they already have all the details and special tools to continue assisting you. I am sure they are doing their best to help you.
See you around.
Best Answer05-19-2022 11:28
05-19-2022 11:28
That happens to me too
Best Answer05-19-2022 13:53 - edited 05-19-2022 13:54
Welcome to the Fitbit Community, @DangerSubaru.
If your Fitbit Ace only shows the Fitbit logo or is not responding to taps, please perform a restart and try to set it up as a replacement device:
If you followed our recommendations without luck, the best way to get help for this problem is to chat with us online or give us a call. Please click here to get connected.
I am going to close this thread since it is too old, but if there is anything else we can help you with, please don't hesitate to start a new topic.
Have a nice day.
