11-01-2018
07:52
03:34
JuanJoFitbit
11-01-2018
07:52
03:34
JuanJoFitbit
My sons Fitbit Ace, purchased in July, is now not working off the charger. I tried the reset 3 times. Any other suggestions?
Moderator edit: format
11-02-2018 19:36
11-02-2018 19:45
11-02-2018 19:45
Hi yes it is fully charged and was previously working with no problems.
11-02-2018 20:27
11-02-2018 20:27
@Shannao Have you tried a restart?
Ace Restart: Press the button on the charging cable 3 times within 8 seconds, briefly pausing between presses. The button is on the end of the charging cable that is plugged into the computer. 8 seconds after the first button press, the Fitbit logo appears on the tracker's display.
11-03-2018 07:44
11-03-2018 07:44
Yes I tried this as well and this didn’t work either unfortunately
11-03-2018 08:06
11-03-2018 08:06
Darn. Sounds like it’s time to contact Customer Service.
11-04-2018 05:56
11-04-2018 05:56
Have you tried cleaning the contacts on the Ace and charger? Sometimes when I charge my devices and I find that they're not charging, this helps clear the connection between the two.
one cruise ship at a time!11-06-2018 03:37
11-06-2018 03:37
@Shannao Thank you for participating in our Fitbit Community! Thank you also for trying the troubleshooting steps that mentioned @Jrdubyakc. I'd like you to try the workaround that shared @DramaQueenDiva. This is also helpful since the contacts of your tracker may accumulate dust sometimes and this doesn't permit the tracker to get a full charge or to charge properly.
Let us know if this does the trick and we'll be happy to follow up!
