07-24-2020 02:10 - last edited on 07-24-2020 15:41 by LiliyaFitbit
My fit bit is on the wrong time 😫😖🥺🥺🥺🥺how do u fix it🥺🥺🥺
07-24-2020 03:05
07-24-2020 03:05
You can't manually set the time, but it should reset itself whenever it syncs to your phone or computer based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the time zone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
