08-16-2019 03:40 - last edited on 08-17-2019 05:03 by JuanJoFitbit
Seriously disappointed with my sons Ace Fitbit, spent almost £80😓 on it last year and now it’s stopped working. Won’t charge or switch on!!!
Very disappointed mum and son😬
08-20-2019 02:38
08-20-2019 02:38
Thank you for your response and helpful suggestions.
Tried all the suggestions then, tried charging with a new charger, Fitbit now working!🙈😅
08-16-2019 08:11
08-16-2019 08:11
Hi, @Shnapc, sometimes Fitbits don’t seem to be charging and won’t turn on when they have, for whatever reason become unresponsive. I would suggest:
1 Give the charging contacts a good clean. Here’s how:
2. Next, clean the pins on the charging cable with a cotton swab and rubbing alcohol. Be careful not to leave any bits of the swab beh8ng.
3. Then plug the Ace in and give it a good two hours charge, even if it does not seem to be charging. Remember if you use a computer to charge that in most cases it will not deliver charge unless it is awake and active. You can use a wall charger if you prefer; just make sure that it is UL/CE certified, The original plug that came with your cell phone is ideal, as long as it will take a usb cable.
4. After 2 hours, give the Ace a restart. Here’s how: Press the button on the charging cable 3 times within 8 seconds, briefly pausing between presses. The button is on the end of the charging cable that is plugged into the computer. 8 seconds after the first button press, the Fitbit logo appears on the tracker's display. This indicates that Ace restarted.
The restart process will often bring a Fitbit that has become unresponsive back to life. If nothing happens, please attempt the restart two or three times more.
If nothing happens following that, please do post again, and someone can help you with the next steps. Good luck!
08-17-2019 05:00
08-17-2019 05:00
@Shnapc welcome to our Fitbit Community! I would like to follow up on the charging issues that your son's Fitbit Ace is experiencing. I totally understand how you feel about this and I appreciate your feedback.
I would like to know if the issue persists or if the Ace started to charge after following the great troubleshooting steps that shared my friend @Julia_G.
If you found her post helpful, please accept it as a solution so other users that experience the same issue can find it easier.
Looking forward to your response!
08-20-2019 02:38
08-20-2019 02:38
08-22-2019 09:10
08-22-2019 09:10
@Shnapc I'm sorry for the late response. However, I'm so glad to hear that the steps shared above were helpful. Thank you for posting the update here.
As a side note, I'd like you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often!
