03-09-2022
00:59
14:22
EdsonFitbit
03-09-2022
00:59
14:22
EdsonFitbit
I had question that how can I enable the heart rate sensors in Fitbit Ace 3?
Is it possible to enable the sensors or not?
Moderator edit: all-caps
03-09-2022 07:07
03-09-2022 07:07
Hi @dhawalPatel1359 no, it doesn't check the heart rate. It's not in the product information or the user manual.
03-09-2022 07:07
03-09-2022 07:07
03-11-2022 00:36
03-11-2022 00:36
03-11-2022 05:37
03-11-2022 05:37
Did you read the links I posted above? Everything about the Ace 3 is in them.
04-14-2022 06:36
04-14-2022 06:36
The Ace 3 is indeed an Inspire 2.with a different firmware. The sensor is present but is deactivated via software and it is not possible to enable it.
