01-07-2024 12:54
01-07-2024 12:54
Ever since I have downloaded the new app, I keep having to re add my devices. I have a versa 2 and my children both have Ace 3s. In the old app, no matter how long I didn’t open the app for, our devices were always saved and just needed to be synced. Now, if I don’t open the new app for a few days, it has lost all our devices and I have to re add everything. It hasn’t saved any data since it lost it. I have re added the same devices numerous times and I am finding this infuriating. Anyone have a similar issue or is there an obvious fix? TIA
Best Answer02-06-2024 12:46
02-06-2024 12:46
Im having the same issue. Its very very frustrating. Whats the fix here fitbit?
02-06-2024 13:09
02-06-2024 13:09
I have the same issues . Have to re/add about everyday .
Best Answer02-11-2024 14:34
02-11-2024 14:34
Are you asking sure that you are logging into the same accounts?
Best Answer02-12-2024 07:30
02-12-2024 07:30
Not sure what you're asking here? I have two fitbits, one is mine and one is my son's. I have to re-add the devices every time I login. This is a huge glitch
Best Answer02-12-2024 08:59
02-12-2024 08:59
I think I may have it sorted after some back and forth with tech support. It’s been a week and I haven’t had to re ad device. See pic attached.
Best Answer02-13-2024 13:49
02-13-2024 13:49
I am having the issue of my son hasn't used his app in a while so its logged out. His watch time needs to be corrected and therefor synced. My google login works on my phone, and on a computer, but it will not work on his ipad. Neither will his google login that we created for the purpose of having a fitbit work. Any ideas on how to get logged into his ipad so his watch can sync?
