07-28-2019 04:26
07-28-2019 04:26
Hi there, my son's ace 2 charger has gone missing. I dont see any replacements i can buy on amazon but the fitbit inspire charger looks very similar. Is the charger for the two watches compatible? Thanks!
07-28-2019 07:39
07-28-2019 07:39
07-28-2019 07:39
07-27-2020 02:22
07-27-2020 02:22
I have the same problem as you it is the smallest charger I have ever seen So it is so easy to loose as I don’t know if the ones on Amazon are going to work?
07-27-2020 20:43
07-27-2020 20:43
