01-01-2022 15:54
01-01-2022 15:54
Hi, I bought an Ace 2 and Ace 3 for my kids this Christmas and have consequently found out that there is an issue with your products concerning the sleep data on the trackers. I am alarmed to find out that this issue has been ongoing for more than half a year and has not been fixed by you. Therefore, can you answer when this issue will be finally resolved so that I can make a decision whether to return the products for a refund or to hold off and wait for a fix from you.
Thanks
01-01-2022 22:49
01-01-2022 22:49
@Daniel888 What issues are you having with sleep tracking?
01-02-2022 15:58
01-02-2022 15:58
The sleep data is not displayed on the Ace 2 and Ace 3. The display just says “no data”. I have to log into the app to see the data.
01-04-2022 03:45
01-04-2022 03:45
It's a very common problem that i experienced as well with my son's Ace 3. I didn't try it yet but i read in this forum that the issue might depend on a particular watchface. Can you try different ones?
01-04-2022 18:32
01-04-2022 18:32
I am having the same issue on my
sons’s Ace3
01-15-2022 02:19
01-15-2022 02:19
Yes, you can pock different clock faces. But it does not fix the problem with the sleep data. I exchanged the Ace 2 for a new one but the new one had the same problem. I finally returned the product for a full refund and bought a product from a different manufacturer.
