Set up silent alarms on Ace
I don’t know how to put silent alarms on ace. Pls don’t send me the link just tell me how. I’ve already checked the links and they are no help, pls help me by telling me in your reply... don’t send me a link
1 REPLY 1
Hi @A_gupta  for the Ace, the silent alarm is set on the actual app, not the device.
Fitbit app
Your device vibrates and flashes when a silent alarm goes off. This notification repeats several times or until dismissed. If you don't dismiss an alarm, it repeats in 9 minutes.
You can also press the button on your device to dismiss an alarm. For Fitbit Ace, Fitbit Alta series, and Fitbit Flex 2, double-tap the tracker to dismiss an alarm.
Reference link
Stepping in the U.S.A. since September 2013. Android 14
