08-22-2018 04:39 - last edited on 09-12-2018 08:23 by KateFitbit
My daughter's first Ace didn't work, so we received a replacement Ace. Now I cannot get the Ace to setup. I receive the error message: FBBluetoothErrorDomain Error 24. I reset the Ace, deleted and reinstalled the app, turned off Bluetooth, restarted iPhone, turned off WIFI and tried using cellular... nothing seems to work. If I try to set up a second time, I get the error message: FBBluetoothErrorDomain Error 22 (for which I found a solution, but that just gets me back to the Error 24 issue). Please help!!
moderator edit: title for clarity
08-24-2018 16:22
08-24-2018 16:22
This post was marked solved.
08-27-2018 14:52
08-27-2018 14:52
I did as you suggested - removed all connections to other devices, restarted my iPhone, restarted the Ace, then tried to go through setting it up again. I am still getting the same error message: FBBluetoothErrorDomain error 24. I have not been able to find anything on the Fitbit help site that addresses this problem. Please provide a solution.
09-03-2018 02:20
09-03-2018 02:20
I have same problem.
Chated with Fitbit online for an hour but didn’t solve.
and he replied in Email after high leveled manager but the reply didn’t help.
09-08-2018 18:00
09-08-2018 18:00
I have the same problem. Very frustrating. Has anyone found a solution to this yet?
09-09-2018 14:53
09-09-2018 14:53
Hi all!
Have any of you verified that your syncing devices are on the "List Of Supported Devices"?
one cruise ship at a time!09-09-2018 16:02
09-09-2018 16:02
09-10-2018 00:53
09-10-2018 00:53
09-10-2018 15:26
09-10-2018 15:26
I steel have same problem.
___________________________________________________
09-10-2018 17:14
09-10-2018 17:14
@Morskimentioned that they're using an iOS, which is fine and thanks for that info. Is anybody using Android and having the same issue? How about Windows? I'm just trying to determine if this is an Apple-specific problem or if it's across the other platforms as well.
@Morski, would you please be so kind as to provide the specs on your iOS, such as model, version, etc.?
one cruise ship at a time!09-10-2018 19:34
09-10-2018 19:34
09-11-2018 17:38
09-11-2018 17:38
@Morski thanks for your report, I've passed your case along to our team to see when a fix may be available.
@colombo13 - thanks for your report, can you confirm you are seeing the same error message? Error 22 or 24?
Actively managing your weight? Find accountability buddies on the Manage Weight board
09-12-2018 07:18
09-12-2018 07:18
I have both error 22 and error24. Please solve the problem asap. Very frustrating.....
09-13-2018 18:10
09-13-2018 18:10
Thank you for replying back @LMom, I've seen this error message with other people that using iOS device, as it was mentioned previously on this thread.
The team of developers is aware of this and is working on a solution. At the moment, I could only advice that you follow the steps listed here: Why can't I set up my Fitbit device? They have been useful to other users experiencing the same difficulties.
I hope this helps.
09-15-2018 18:30
09-15-2018 18:30
Many have got around this error by using a non iOS phone to setup the tracker. Some simply have borrowed a friend's phone.
09-16-2018 23:40
09-16-2018 23:40
09-17-2018 09:55
09-17-2018 09:55
@Morski wrote:
Thanks for your suggestion. I tried this last night on an android phone and computer and still had not luck. VERY FRUSTRATED!!
This may be a shot in the dark, but have you tried setting the Ace up via a tablet?
one cruise ship at a time!09-17-2018 10:21
09-17-2018 10:21
@Morski Thank you for getting back! I'd like to follow up on your post and since you mentioned that you tried with an Android phone, is the device compatible? You can check out this page in order to find out if the Android device you used is in the Compatible Devices list.
@Rich_Laue @DramaQueenDiva Thank you for your help my friends!
See you all later!
09-18-2018 22:45
09-18-2018 22:45
09-20-2018 04:10
09-20-2018 04:10
@Morski Since your Ace can't still be set up, let me go ahead and send your case to our Support team so they can investigate further and follow up with this. You should receive an email from them soon.
Let me know if you have additional questions!
