03-13-2018 21:01 - last edited on 03-15-2018 09:11 by ErickFitbit
Hi, l just wanna know Fitbit Ace is same with Alta? Same size? What can the kids do with it? It is said you can track sleep duration & sleep schedule, how to make it ? Thank you.
Moderator edit: edited title for clarity
07-19-2018 09:46
07-19-2018 09:46
Hi @Niclass, and welcome to the Community forums @aknbuffy, it's good to see you both around.
I can confirm the charging cable for Fitbit Ace and Fitbit Alta is the same, however, please note that the cable for Alta HR is different. Here you can find the charging cable and other accessories.
I hope this helps.
07-27-2018 09:08
07-27-2018 09:08
Bought my son the ace and my son is pretty thick his 9yrs old and I asked the guy if it would fit my son my son was there he said yes it’s all one size fits all but unfortunately it didn’t fit it was too tight for his wrist so Im reading in the comments the Alta will fit so I’m guessing I will go with a Large !
07-29-2018 09:34 - edited 07-29-2018 10:06
Hi @Jellybean1, it's great to see you around in the forums.
I'm sorry to see that happened with the Ace wristband being too tight, as you mentioned, Fitbit Alta and Fitbit Alta HR wristbands are compatible with Ace. The extra small wristband that comes with the Ace is shorter than Alta and Alta HR bands in size small. The Ace wristband fits wrists 5.0” - 6.34” in circumference.
I have also sent your information to the Customer Support team for further assistance with this, you should receive a reply soon.
I hope this helps.
08-02-2018 01:42
08-02-2018 01:42
The alta has Call Alert, With SMS Notification, With Calendar Notification and the Ace does not.
08-02-2018 15:24 - edited 08-02-2018 15:24
08-06-2018 13:08
08-06-2018 13:08
Is the tracker part of the Ace the same size as the Alta? Are the bands the only difference in size?
08-07-2018 16:37
08-07-2018 16:37
Hello @lwmeche, welcome to the Fitbit family and the Community forums.
It's a good question, the pebble or tracker itself for Fitbit Ace is actually the same size as Fitbit Alta and Alta HR, it's about 3.5" in length. You can check the image in this post as a reference.
As you mentioned, the other difference in size would only be with the wristbands.
I hope this helps.
09-08-2018 07:47
09-08-2018 07:47
My 10 yo who is very slim with tiny wrists, has his Ace on the third hole comfortably. A bit loose, as recommended. I tried to post pic, but this website is not mobile friendly.
09-09-2018 16:14
09-09-2018 16:14
I read its the same size as the alta. I assume its tracks steps, sleep. challenges, reminders to moves, goal.
09-12-2018 12:08
09-12-2018 12:08
@Purplycat Welcome to our Fitbit Community! I'm glad to hear that your child's Ace wristband fits great. I also appreciate your feedback about the website. This helps us to keep improving our services.
@colombo13 That is correct! The info you described can also be verified in this page.
I'll be around if you guys have any doubts!
10-11-2018 07:16
10-11-2018 07:16
Good to know about the sizing of the Ace band. I have an Alta HR and the band is too large for my tiny 5 1/4" wrist. After a while the band stretches out resulting in my tracker not working properly.
10-11-2018 07:26
10-11-2018 07:26
10-11-2018 16:18
10-11-2018 16:18
Hello @phedder and @Jellybean1, it's great to see you around.
@phedder, it's a good thing that you found this information about the wristband sizes then.
Great @Jellybean1, thanks for sharing that information as well, I'm sure it will be useful for other users too.
Keep on stepping.
10-24-2018 05:54 - last edited on 10-29-2018 08:12 by JuanJoFitbit
The two devices are the same physical size but the have different functions. The ace has a subset of the Alta’s functions. See the comparison charts on the Fitbit site for all the details.
Moderator edit: format
10-29-2018 08:11
10-29-2018 08:11
@FTutone Welcome to our Fitbit Community! Thank you so much for your contribution and feedback about the size of the Fitbit Alta and Ace.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community!
