06-17-2018 23:51
06-17-2018 23:51
Hi, I have tried setting up the Ace on 2 different devices but I keep getting the following error message
“there was a problem communicating with your tracker please try again”
I see the 4 digit code on the device, my iPhone says it’s connected but just get the error message when I enter the code. I have tried turning Bluetooth off and on, restarting app but still no joy.
Any ideas?
Thanks
06-18-2018 07:31
06-18-2018 07:31
I have exactly the same issue..i've been trying since 12th June to set this up. It keeps stating that it has found "ace" and I enter the 4 digit code but then just keeps turning round and round saying "connection". Driving me crazy and I feel like throwing the **ahem** thing in the bin.
06-18-2018 23:27
06-18-2018 23:27
Well it’s worked, happy days. The only thing we did different was the little one had it on his wrist when we entered the code, could be luck but at least it’s now connected.
06-19-2018 16:30
06-19-2018 16:30
@HenryFit, @Tanya72 Welcome to the Community thanks for your reports. @HenryFit I'm glad to hear you were able to get the tracker started.
@Tanya72 I would try restarting the tracker if you haven't done that already. If you still can't set up, what type of device are you trying to set up with? Is it possible to try setting up on an alternative device?
Actively managing your weight? Find accountability buddies on the Manage Weight board
06-20-2018 01:53
06-20-2018 01:53
06-20-2018 18:17 - edited 06-20-2018 18:18
@Tanya72 Sorry to hear it's still stuck. I created a case so someone can reach out to you via email, hope they can get you set up.
06-21-2018 10:59
06-21-2018 10:59
06-21-2018 17:37
06-21-2018 17:37
@Tanya72 Sorry to hear this. The best bet is to discuss the syncing issue with customer support who can take an in depth look into what's going on and why your steps are disappearing.
07-02-2018 11:30
07-02-2018 11:30
Restarting the Ace worked for my child's Ace. The same article has been posted by several users and moderators: http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart+alta&l=en_US&fs=Search&pn=1
My child's Ace was not syncing to any of our devices, so I tried removing and re-adding it to my child's profile. However, when trying to add it back, the syncing process would fail after entering in the 4 digit code. The app was able to connect to the Ace up until entering the 4 digit code, but the final connection would not complete. When that didn't work, I tried the restart method that NellyG mentions, and that solved everything.
Restarting the Fitbit will be my go to 1st step for troubleshooting from now on. The good thing about restarting is that it does not wipe out any of the data on the fitbit. It's a straight-up reboot.
07-02-2018 14:18
07-02-2018 14:18
We are having the same issue whilst setting uP our daughters new FitBit Ace, after entering the four digit code we get an ‘http error 500’ code come up?
Attempted the reset many times (by holding the button on the charger) & it searches for the device but we still haven’t manage to sync it with her ipod.
07-27-2018 06:06
07-27-2018 06:06
I still have the same error as well. Even with other devices the Ace won't connect to a phone at all. Resetting the Ace didn't help either.
Do you have any suggestions?
Kind regards,
Eric
07-27-2018 06:31
07-27-2018 06:31
07-27-2018 08:15
07-27-2018 08:15
07-31-2018 13:38
07-31-2018 13:38
Awesome @bojoe22, and @Tanya72, it's good to know this worked for you, thanks for sharing your experience.
Also thank you for these details @LoisRankin and @Eric_G75, if you already tried the steps to restart the Ace, make sure you've also tried all the instructions provided here to resolve problems with the setup process. I was going to send your information to the Customer Support team, but I was informed that you already have a case created with them and they're providing you assistance with this. I hope everything goes well.
Keep us posted on the outcome.
01-02-2019 21:54
01-02-2019 21:54
Did you ever get an answer to this that actually solved the issue?
01-02-2019 22:56
01-02-2019 22:56
01-03-2019 14:38
01-03-2019 14:38
It's good to see you around in the forums @drandsii, could you please provide some more details about what you've experienced? Are you getting the same error message mentioned above "there was a problem communicating with your tracker please try again"? Have you tried the steps mentioned previously to try to find a solution?
It's great news @Tanya72, thank you for the update.
01-05-2019 17:06
01-05-2019 17:06
My post should not have been in this thread. I am not receiving any error message. Thanks.
01-08-2019 06:16
01-08-2019 06:16
