ACTIVE MINUTES WONT REGISTER ALTHOUGH STEPS AND HEARBEAT DO
I have repeatedly reset my Fitbit and while my heart rate and steps do log, the active minutes section does not change from 0. I have just done a workout which didn't log at all. Would appreciate any advice. Thanks
3 REPLIES 3
Hi @Ninjanina  Although the active minutes are calculated using data the Alta HR collects, the calculation is actually done in the app/fitbit servers. If you are getting Heart Rate recorded then it is probably a fault with the app. Try uninstalling it from your phone, then reinstall it and log back in. Hopefully that will fix it
Community Council Member
Helen | Western Australia
Active minutes are not the same as mites of activity @Ninjanina. What type of workout? Was it a workout that Fitbit will auto detect??
It’s all fixed! Had to reset app.
Thanks
Nina
Sent from my iPhone
