12-03-2017
14:09
20:08
12-03-2017
14:09
20:08
Hi. Like many others, I have had problems with the band breaking away from the device. I've tried two replacements from Fitbit without any luck.
Has anyone found a third-party replacement band that doesn't break? I'd love a recommendation.
09-29-2019 19:40 - last edited on 10-10-2019 16:48 by LiliyaFitbit
Sent from my iPhone
____________________________________________________________
Moderator edit: content
10-01-2019 08:12
10-01-2019 08:12
I found this replacement:
https://www.amazon.com/gp/product/B07PYRQ64K/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
I've only had it for 2 months but it feels more secure than the Fitbit band EVER did. Have had absolutely NO problems.
10-01-2019 13:35
10-01-2019 13:35
10-01-2019 13:48
10-01-2019 13:48
10-01-2019 17:37
10-01-2019 17:37
10-02-2019 10:13
10-02-2019 10:13
I just started having this issue, took the band off completely, looked at each band horseshoe attachment points and noticed the plastic housing on the side that breaks away is no longer stiff, it is flexible. The other side is still intact. This looks like a manufacturer's design flaw, using plastic horseshoe connection points instead of metal. I now have to contact Fitbit to get a replacement, if they will give me one. I'm hoping the horseshoe clip is metal instead of plastic.
10-02-2019 12:59
10-02-2019 12:59
10-02-2019 13:09
10-02-2019 13:09
Simonetti, you should go to the Fitbit website and if you don't have an account, create one. Go to contact support, then broken band call to action and you can file a claim because the Fitbit band has a warranty. They want photos, and a receipt. I bought my Fitbit Alta HR from Amazon, and a 3-year coverage, but the broken band issue seems to be something they know about, maybe not in R&D, but at least within Marketing since it's on their website. And if people post to Twitter and hashtag then it'll find traction. I purchased a 3 pack of replacement bands from Amazon for the time being, if they are plastic, I don't expect a long lifespan for them. I hope you have luck.
10-03-2019 07:30
10-03-2019 07:30
10-14-2019 11:24
10-14-2019 11:24
My Alta HR strap broke yesterday, in the same place everyone complains of. This is seven months old, bought in the UK (so guarantee is UK law). This is their reply. “Keep in mind that our warranty policy doesn’t include replacement for damage due to normal wear”
What a joke, this is the UK, with UK law, not American law. Normal wear not covered???
10-14-2019 16:47
10-14-2019 16:47
10-16-2019 23:38
10-16-2019 23:38
10-17-2019 00:15
10-17-2019 00:15
Yes I wear it when sleeping, but it is designed to do exactly that as it measures your sleep. It seems many people have the same problem, it fails where the strap connects to the Fitbit. They finally agreed to send a replacement (UK has a two year warranty as clearly printed in the Fitbit booklet). They kept moving the goalposts and wanting more and more proof, but in the end they finally agreed to a replacement. We expect these things not to fail in a few months, it is clearly a design fault. I needed a copy of the receipt, code from the box (thank heavens I kept it), the fault code from their email writing on the photo of the Fitbit (had to be written on the photo!), the list of demands was long.
10-17-2019 00:56
10-17-2019 00:56
I do wear mine when sleeping and I also toss and turn. Fitbit will send you a replacement, but you need to take a few images on the broken end and send it in to them. If it is part of the design flaw, Fitbit does not hesitate to send you a replacement band. I am still waiting to hear, what, if anything they plan on doing to address the issue with a new design, a single/one piece squared horseshoe attachment in the band, maybe made from metal or a more dense piece of plastic. I hope you are able to get a replacement.
10-17-2019 01:02
10-17-2019 01:02
It definitely is a design flaw or a flaw in manufacturing. It sounds like you had to jump through way more hoops than I. I only needed to send images of the defective end and Fitbit quickly replaced the band. I was quite surprised how fast I received it actually. Any company that honors their product in this manner is a good company in my opinion. Not to mention, they have provided a forum for us to communicate, not all companies do that on their websites. They are also addressing the Apple iPhone iOS 13 issue some people are having. Thank you Fitbit!
10-17-2019 07:40
10-17-2019 07:40
10-17-2019 21:21
10-17-2019 21:21
10-17-2019 23:09
10-17-2019 23:09
It’s DEFINITELY a design fault. Lol. I don’t recall the details of which side the strap failed but it failed the same exact way both times, very quickly, with sporadic use (not constant or ever overnight). It sucks. 😂
10-18-2019 06:41
10-18-2019 06:41
10-20-2019 18:20
10-20-2019 18:20
Fitbit replaced my first band. I haven't contacted them about this one. I think I'll have to pay.
