12-03-2017
14:09
20:08
12-03-2017
14:09
20:08
Hi. Like many others, I have had problems with the band breaking away from the device. I've tried two replacements from Fitbit without any luck.
Has anyone found a third-party replacement band that doesn't break? I'd love a recommendation.
02-20-2020 00:03
02-20-2020 00:03
02-20-2020 04:46
02-20-2020 04:46
02-20-2020 04:49
02-20-2020 04:49
02-20-2020 08:27
02-20-2020 08:27
04-19-2020 04:33
04-19-2020 04:33
Same here. They sent me a replacement but then it broke and they told me it was no longer under warranty. There is no way I'm going to buy one from Fitbit, I've had nothing but problems with their products. I can't believe I bought a second one after the trouble with the first, but I like the app and I had already stored so much data in it and didn't want to start from scratch with a new product. Will definitely shop around for my next device and it will not be a Fitbit!
04-19-2020 14:48
04-19-2020 14:48
04-19-2020 20:06
04-19-2020 20:06
05-26-2020 17:14
05-26-2020 17:14
I started wearimg my with the watch part on the i side of my wrist. Also try keeping it loose. Also I found if you clean the areas where it connects it helps some. I found my get dirty some how. The release clip seems to get loose but if you very gently pull out on it the band should snap into place. The stainless steel band I found online did not last. Really surprised about that.
05-26-2020 19:42
05-26-2020 19:42
07-24-2020 11:45
07-24-2020 11:45
I totally agree with you! Such a shame that Fitbit does not seem to continue to support it's older products and just continues to make new models. My Alta HR is only 2 years old and now I am unable to find a replacement band. Appreciate the candid post
02-28-2021 04:38
02-28-2021 04:38
Have experienced the exact same thing and have wasted 30 minutes trying to find/shop for yet another replacement band.
Have almost lost the watch numerous times... will NEVER purchase Fitbit again.
02-28-2021 06:11
02-28-2021 06:11
02-28-2021 07:25
02-28-2021 07:25
There are lots of replacement bands for the Alta HR on Amazon. I bought these ones and I found them to be more comfortable than the original band that came with my device. I also liked being able to choose between different colors. I used those bands for more than two years and never had any problems with them.
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
02-28-2021 08:19
02-28-2021 08:19
