04-11-2018
05:03
20:08
04-11-2018
05:03
20:08
My fit bit won't hold a charge it is taking all day just to charge up to half way however when you wear it it dies shortly after. I love my fit bit but it's clearly not working. it is connected properly and kept in very good condition
04-11-2018 05:07
04-11-2018 05:07
Clean the contacts on the charger and tracker using an alcohol wipe then put it on charge using a different USB slot or different wall charger to your usual one, and restart it several times. Leave it charging till fully charged and see if it reaches full charge in a couple of hours. Let us know how you go.
Helen | Western Australia
Best Answer04-11-2018 05:23
04-11-2018 05:23
04-11-2018 06:22
04-11-2018 06:22
I think you will need to contact Support if none of that has helped. Link in my signature
Best Answer04-30-2020 09:07
04-30-2020 09:07
My Alta will not hold a charge. At this point it is useless because it will not track my steps. I use the app
