02-11-2019
08:02
20:08
02-11-2019
08:02
20:08
The display on my band is scrolling through time, steps, heart rate etc non -stop. After a certain period of time the scrolling stops but then the display goes blank and won’t reawaken with tapping. Will only come back on if I put it on the charger. Green heart rate monitor lights are always on even though setting is on Auto. I have tried the reset sequence numerous times and all I get is the Fitbit logo and the battery icon— never get to the screen where the software version shows up. Put band in rice overnight just in case there was water in battery/case. Fitbit was purchased July 2017 so it’s out of warranty. Has anyone else experienced this? Any remedies?
Moderator edit: format.
08-08-2020 18:45
08-08-2020 18:45
Best Answer08-08-2020 21:24
08-08-2020 21:24
08-09-2020 19:39
08-09-2020 19:39
I had no luck! Try putting it in a bag of rice to dry it! Mine was damp inside from my workout! Sweat go figure a fitness tracker that cannot get wet even a little! I had to throw mine out. Have not replaced it yet but lean towards an Apple each that you can actually swim in!
04-03-2021 11:33
04-03-2021 11:33
Any resolution?
Best Answer04-03-2021 12:01
04-03-2021 12:01
Best Answer04-03-2021 13:10
04-03-2021 13:10
18:43
12:05
JuanJoFitbit
09-09-2021
18:43
12:05
JuanJoFitbit
I have a screen that is cracked and now endlessly scrolling. After reading these posts I decided to blow dry the device. Worked and back to normal know.
03-18-2022 15:56
03-18-2022 15:56
I am having the same issue with my Fitbit Alta HR. Tried to reset it but to no avail. Quickly scrolls through date, time steps, HR. Date is incorrect. So frustrated. Any solutions?
