02-18-2019
02:57
20:08
02-18-2019
02:57
20:08
Is it possible to get a replacement screen for the Alta HR or get it repaired? Mine has a crack running from top to bottom although I have not knocked it against anything or dropped it. I'm really disappointed as it is less than 2 years old.
08-22-2020 15:29
08-22-2020 15:29
Garmen
Best Answer08-22-2020 15:51
08-22-2020 15:51
Best Answer08-22-2020 15:52
08-22-2020 15:52
Best Answer08-23-2020 05:37
08-23-2020 05:37
Best Answer08-23-2020 07:19
08-23-2020 07:19
Best Answer08-23-2020 07:24
08-23-2020 07:24
I had the Alta HR for less than six months when my screen cracked. It's still under warranty, but they no only offered me a discount on a new one too. They did replace the band that was defective. 😞
Best Answer08-25-2020 21:01
08-25-2020 21:01
Best Answer08-26-2020 11:48
08-26-2020 11:48
Bought it on Amazon by third party seller & seller says it's Fitbit's responsiblity.😒
Best Answer11-26-2020 13:50
11-26-2020 13:50
I too have a crack top to bottom. More than 1 yr old but less than 2. Not sure how or when I got it - it suddenly appeared. I know it was definitely not a significant blow to my wrist to have caused it. Pretty primitive but I have placed clear tape over the screen especially if increased risk of moisture. (i.e. walking in the rain)
Best Answer11-27-2020 05:09
11-27-2020 05:09
04-25-2021 23:50
04-25-2021 23:50
Where did you get the screen protectors from? Mines cracked too same thing It ws on charge and I picked it up to put back on and noticed the crack. Mines older than 2 years I think so sounds like it won't get replaced or fixed. Delaying the inevitable having to buy a new one if a screen protector will help for a bit I'll try it.
Best Answer04-26-2021 05:53
04-26-2021 05:53
Best Answer04-26-2021 06:42
04-26-2021 06:42
Best Answer04-26-2021 10:18
04-26-2021 10:18
Best Answer04-29-2021 02:01
04-29-2021 02:01
I got mine from Amazon - search for Fitbit Alta HR screen protector including the words HD/Durable/Scratchproof and Explosionproof (Fitbit will not allow me to post the name of the manufacturer for some bizarre reason) and they should come up. Mine came as a pack of 4 protectors - you do need to replace them every few months as they lose their stickiness and peel off. But it seems to help protect it from scratches and so far no crack has appeared again.
Best Answer06-10-2021 12:34
06-10-2021 12:34
Same thing happened to mine.
