Alta HR bands converters
After purchasing a gunmetal Alta HR for the second time, I do not wish to purchase a third. Just prior to buying the second Alta HR, I bought an Inspire HR as a replacement tracker. However, I  discovered that the Alta bands aren't interchangeable with the Inspire HR. I have loads of Alta bands. Why doesn't Fitbit offer a converter so the bands are interchangeable?
1 REPLY 1
Hi @TMR21  the newer styles are able to swap bands more easily, so your next Fitbit might be able to do that. For many, a converter might be more clunky, so it wouldn't be something they would use.
Stepping in the U.S.A. since September 2013. Android 14
