11-01-2020
20:24
11:14
AnaFitbit
11-01-2020 20:45
11-01-2020 20:45
Hi @kingDave83 you should edit your post to remove your personal information. The Alta series was retired quite some time ago. I doubt it is still under warranty. Have you tried cleaning the charger itself?
11-01-2020 20:51
11-01-2020 20:51
I tried that it’s not charging at all
01-06-2021 11:16
01-06-2021 11:16
Hi @Odyssey13, thanks for your help with this!
Hi @kingDave83, let me give you a warm welcome to our Community!
Thanks for the troubleshooting performed before reaching out. If the issue persists with your Alta HR and if you haven't tried this, you can follow the suggestions in this link Why isn't my Fitbit device's battery charging?.
If your tacker has an HR sensor (green LEDs) you're using an Alta HR, if not you're using an Alta. Take this into consideration when verifying the restart instructions on the help article.
Let me know how it goes.
