12-29-2020
08:45
06:47
WilsonFitbit
12-29-2020
08:45
06:47
WilsonFitbit
I am trying to set up an AltaHR with my MacBook Pro running Macos X 10.11.7. I had been using the software SUCCESSFULLY with an Alta. During the process of trying to set up the additional tracker the Fitbit SW - Fibit Connect - lost the ability to open the Main Menu. The window appears but all I get is the spinning gear. The Alta still syncs and the Dashboard is still available but no joy with the Main Menu.
I have tried the latest version of Fitbit Connect (2.0.2.7241) and also the previous version (2.0.1.6813) without success. The computer has Bluetooth 4.0 which I understand is needed for the latest version.
What an I missing?
Thanks.
01-06-2021 06:57
01-06-2021 06:57
Hello @deeceehs37 Welcome to the Community Forums!. Thanks for your help in trying to resolve this inconvenience.
You mentioned that Fitbit connect is not giving the option to open the Main Menu. In order to further assist, could you provide a screenshot of the spinning gear icon you get?. To attach an image, please follow the tips here.
As you mentioned, the Alta HR can be setup using a Bluetooth-enabled Mac. In the meantime, please try the suggested tips from the following help article: Why can't I set up my Fitbit device?
Keep me posted if the issue persists.
Best Answer01-06-2021 16:20
01-06-2021 16:20
Best Answer01-07-2021 04:17
01-07-2021 04:17
Hello @deeceehs37 It's great to see you around.
Your help is very appreciated. It seems that the screenshots weren't attached but since this sounds a bit more serious. I’ve created a support case on your behalf. You should receive an email from Customer support. Note that we may take a bit long to get back to you due to recent events affecting our operations.
Have a nice day!.
