11-17-2022
19:12
02:45
11-17-2022
19:12
02:45
my alta hr screen cracked. It still works but I get worried about hurting myself. Is there a point in trying to save it?
11-17-2022 19:34
11-17-2022 19:34
Hi @AnimeDancer24 I used to wear an Alta HR myself. It's really up to you what you feel is the best decision. With a cracked screen, there's no way to fix it. Sales are going on all over and if you were thinking of getting a new device, it might be the best time to be looking. I have the Luxe, which has a brighter screen and softer band than the Alta HR. It's a tad slimmer, too. You could check on Amazon for some sort of protective cover for the screen, but it might be hard to find since the Alta HR has been discontinued.
11-17-2022 19:38
11-17-2022 19:38
Mine is very old to be fair.
Best Answer11-17-2022 20:50
11-17-2022 20:50
@AnimeDancer24 it would work as a back up, so I wouldn't trash it. The Alta series was replaced by the Inspire series and the latest in that is the Inspire 3. Sad though.
