09-13-2020 02:09
09-13-2020 02:09
Hello, I have a Fitbit Alta HR which I like very much but yesterday evening stopped working suddenly. The screen went black and the band didn’t syncronize or register any activity. I tried to restarted it but didn’t work. At a moment started to vibrate continuously while in charger but still didn’t work. Could you help me please?
Thank you,
09-13-2020 03:49
09-13-2020 03:49
Same thing happened to me during the night. But I cannot get it to charge either.
09-13-2020 05:16
09-13-2020 05:16
My Alta died as well. I have charged for a whole day and nothing... please advise asap.
Was this a planned outage for Alta's?
09-14-2020 02:10
09-14-2020 02:10
I had exactly the same, this morning. I was going to stop my silent alarm and it completely died...and will not charge either. Very suspicious that I an not the only one. Wondering what to do now...
09-14-2020 06:36
09-14-2020 06:36
Last night my Fitbit Alta died so I went to charge it and an exclamation mark popped up... whatever I do this exclamation mark will not leave. Tried to reset but that exclamation mark is stubborn and won't leave not sure what to do now =(
09-14-2020 07:53
09-14-2020 07:53
Buenas tardes:
Tengo problemas continuamente con el apagado de mi dispositivo Fitbit HR Alta versión 26.63.2. Llevo una temporada en la que se me apaga, le tengo que reiniciar y al rato lo mismo.. Se ha convertido en un problema recurrente, espero me podáis dar una solución
Saludos
09-15-2020 10:36
09-15-2020 10:36
This happened to me about two weeks ago! So weird. I thought it was because I got it wet but even after putting it into a bowl of rice for over 24 hours, it still doesn’t work.
09-15-2020 13:02
09-15-2020 13:02
This happened to me yesterday as well! Or to be clear it didn't die in the literal sense, the screen first started going crazy - flickering between all the screen modes rapidly, which emptied the battery pretty quick. I charged it back to full and now the screen is stuck on showing battery level. I can no longer make it change by tapping it or by adjusting screen settings with the mobile app. I attempted to reset the device multiple times (press the button in charging cable 3 times and disconnecting it) without any luck.
The flickering issue started soon after I used the app and synced manually. I wonder if there was a software update which broke the device. Fitbit app shows firmware version to be 26.26.63.2
Ideas on how to proceed welcome.
09-15-2020 14:56
09-15-2020 14:56
My Alta hr has been slowly dieing for the past week. Screen fading and pixels dropping out of watch face. Started each morning when the silent alarm went off that it would buzz and die - needing to be reset on the charger cable - pressing 3 to 10 times to restart. It has now over the past few days stopped working at various times during the day, needing to be restarted - and then this evening whilst on a run upon reaching target steps for day it buzzed and died to be restarted again on the charger cable.
However, it has now recorded 16,230,000 steps rather than 10,000. Would be great to be able to correct that as it will affect averages and trends!
I’ve had it just over 2 years so it’s out of warranty - the cynic in me feels like it’s built in obsolescence with a kill switch to move people onto the newer versions!
09-15-2020 15:14
09-15-2020 15:14
Mine died today just shy of 10,000 steps, even though there was at least a 50% charge. Continued my walk home -- at least another 2000 steps (bummer!) -- and after plugging it in to charge, it came back on and began charging. Now very wary that this will continue to happen. It's probably close to two years old, I can't afford a new one right now, but after years of depending on a Fitbit, I can't live without one. UGH!
09-16-2020 05:10
09-16-2020 05:10
Mine just stop working also, after reading all the post, why would this many quit working this week?
09-18-2020 09:49
09-18-2020 09:49
Mine stopped earlier this week too. I thought I'd got it wet and decided to buy a Inspire HR as a replacement. It arrived today and that doesn't work either.
09-20-2020 11:56
09-20-2020 11:56
Mine died as well. Just past the 2 year mark.
09-20-2020 13:16
09-20-2020 13:16
Hello, this exact thing has happened to me 5+ times in recent weeks. It gets near the "party" (just shy of 10k) and vibrates and dies. VERY frustrated - also, same thing - 2+ years for me for this, (5+ years with a Fitbit) and likewise I cannot live without it. I guess I'll buy an Inspire, but really hate to spend more money with FB ! Good luck to you.
09-20-2020 22:18
09-20-2020 22:18
No steps recorded today. Haven’t worn my Alta HR for a couple wks and charged it, wore it & now not recording.
09-22-2020 05:29
09-22-2020 05:29
Me too
09-22-2020 05:33
09-22-2020 05:33
09-23-2020 07:13
09-23-2020 07:13
Mine died yesterday. First it wouldn't sync with my phone. Then screen went blank so I thought it might be out of battery and I charged it. While charging it began flickering rapidly through screen modes. Now is locked on the battery level, showing fully charged. Tried resetting several times, no response. Tried cleaning contacts on both Fitbit and charger. Tried resetting again. Still no response. Is there anything else to try?
09-23-2020 07:32
09-23-2020 07:32
