01-22-2020
01:42
20:01
01-22-2020
01:42
20:01
The display on my Alta HR, though charging fine and syncing OK, has disappeared. I have tried several times to reset it to no avail. Any suggestions?
01-22-2020 11:48
01-22-2020 11:48
I put my Alta HR on charge this morning, synced at 0730. then the screen just went blank. nothing, and the devise can't be found. not charging at all now. Its died...…..
Best Answer01-22-2020 11:55
01-22-2020 11:55
My Alta HR is just over 12 months old. Died today. Have tried charging it to no effect.
Have noticed the last couple of weeks. It hasn’t been recording data - steps, sleep etc. Have tried resetting it but no luck there either.
01-24-2020 01:27
01-24-2020 01:27
My Alta HR died today... also cleaned connections & still will not charge. Any suggestions? Are replacement batteries an option? Thanks
Best Answer01-25-2020 06:53
01-25-2020 06:53
Best Answer01-25-2020 22:30
01-25-2020 22:30
Best Answer01-26-2020 16:57
01-26-2020 16:57
I’m having the same issue, screen went blank, charge lasts for about 24 hours and randomly not counting steps.
any luck with determining what is going on?
Best Answer01-26-2020 21:54
01-26-2020 21:54
Best Answer01-26-2020 23:12
01-26-2020 23:12
Best Answer01-29-2020 20:22
01-29-2020 20:22
Same thing happened to me! Less than 12 months old. 😠 Fitbit app says the battery charge is full, but can’t “find” it to sync.
Best Answer01-29-2020 22:07
01-29-2020 22:07
