11-21-2018
03:27
20:08
11-21-2018
03:27
20:08
Hi,
This morning my screen has decided it doesn't want to display anything when I tap or swipe it. My battery is half charged and I have tried doing a reset of my tracker but to no avail.
Thanks
Moderator edit: Updated title for clarity
09-09-2020 06:22 - last edited on 11-09-2020 16:13 by LiliyaFitbit
I ended up getting a new one as well but I received 50% discount on a new
one as mine was still under warranty. I upgraded to the versa
Kind Regards
Best Answer09-09-2020 12:01
09-09-2020 12:01
Best Answer09-21-2020 08:06
09-21-2020 08:06
Hello,
I tried the restart option on fitbit alta hr. No display, although it syncs with my phone and vibrates when I plug it in. Please help.
Sincerely,
Argha.
Best Answer09-21-2020 09:32
09-21-2020 09:32
Best Answer09-21-2020 11:49
09-21-2020 11:49
Best Answer09-25-2020 08:52
09-25-2020 08:52
09-30-2020 13:55
09-30-2020 13:55
This didnt work for me. My fitbit vibrates when I press the button, but my screen is still black.
any ideas??
Best Answer09-30-2020 14:12
09-30-2020 14:12
Best Answer10-10-2020 12:43
10-10-2020 12:43
I’ve tried your suggestions on trying to fix display on my Fitbit Alta HR and the three button presses on charging cable still isn’t working. My phone is connected to it and registering steps on phone but nothing on Fitbit screen?
Best Answer10-10-2020 15:56
10-10-2020 15:56
Best Answer10-13-2020 10:08
10-13-2020 10:08
Hello I have exactly the same issue and they asked me to restart/reboot and did not work while screen remain blank buat I can still sync and use it and collects data to my phone.
Called the CS and they said warranty is out and nothing they can do.
Any help is much appreciated
Best Answer10-13-2020 10:39
10-13-2020 10:39
Best Answer10-15-2020 00:15
10-15-2020 00:15
Hi, i have a similar problem to the one you tried to resolve previously and I'm following your advice but my charging cable doesn't have a button to depress to reset the Alra. Is there another way? Alta shows fully charged on app but no display. Thanks in advance!
Best Answer10-15-2020 09:01
10-15-2020 09:01
Best Answer10-17-2020 07:02
10-17-2020 07:02
Hello. Having the same problem. And have restarted it many times now!
Battery is full. Synced to my phone app. But display is not working when it is not connected to the charger. HELP
10-17-2020 09:44
10-17-2020 09:44
Best Answer10-17-2020 12:05
10-17-2020 12:05
Hi. A friend gave me her almost new Alta in the original box. The charger has no button on it so I can't reset. 😞 The device worked for a month or so, but now the screen stays black when I put it on. When I plug it in the battery is fully charged. Any way to reset it or wake it up with the button-less charger? Thanks!
Best Answer10-27-2020 13:54
10-27-2020 13:54
I was piggybacking on this question.
My Alta HR had low battery several days ago, I put it on charger overnight...it charged, I wore it the next day. By end of day screen was blank. I have tried charging it several times since then. It doesn't light up or display anything when I put it on the charger; it doesn't vibrate when I put it on the charger. It gets warm to the touch but that's it. I tried what you suggested above about rebooting...still nothing happens.
10-27-2020 15:26
10-27-2020 15:26
Best Answer04-16-2021 06:40
04-16-2021 06:40
Hello, my screen is still black after I did the recommended restart. Is there anything else I can do?
jodi
