11-21-2018
03:27
20:08
11-21-2018
03:27
20:08
Hi,
This morning my screen has decided it doesn't want to display anything when I tap or swipe it. My battery is half charged and I have tried doing a reset of my tracker but to no avail.
Thanks
Moderator edit: Updated title for clarity
12-03-2018 06:56
12-03-2018 06:56
Good morning,
The Fitbit was issued to me as part of a Clinical Study, so I don't have all of the information Support needed to go any further. The tracker does seem to be gathering data even when the screen is black, so for now I'm just wearing next to my Ionic.
Thanks for checking.
K
Best Answer12-03-2018 07:09
12-03-2018 07:09
Yeah I got help and I'm very happy 🙂
Best Answer12-24-2018 20:06
12-24-2018 20:06
I have the same issue. Fitbit Alta won't display unless it's plugged in. I followed reboot instruations but still no display unless I'm plugged into computer.
12-24-2018 22:54
12-24-2018 22:54
@mattc57 contact Support (link in my signature)
Helen | Western Australia
04-05-2019 21:55
04-05-2019 21:55
My Alta hr Fitbit screen is blank. It is still tracking steps. When I plug it in the battery life displays. I do not know how to turn my Fitbit off - it has no buttons on it or on the charger. Suggestions for a fix are to turn off thebfitbit but I don’t know how to do that - maybe it is a model that does not turn off. How do I get the screen restarted.
Best Answer04-06-2019 18:15
04-06-2019 18:15
I'm having the same issue. My Fitbit Alta HR display no longer works, there is no reset button. It is still tracking data as I can see it in the app dashboard. I would love to know how to get the display working again.
Best Answer04-06-2019 19:43 - last edited on 10-10-2019 16:53 by LiliyaFitbit
Sent from my iPhone
Best Answer04-08-2019 05:57
04-08-2019 05:57
Did you want me to call you? I see no message.
Best Answer04-08-2019 06:21
04-08-2019 06:21
Best Answer04-09-2019 10:30
04-09-2019 10:30
What fixed it? I still have the problem.
Best Answer04-09-2019 11:12 - last edited on 10-10-2019 16:53 by LiliyaFitbit
I found the button they speak about - it is on the charging cord at the end you plug into the wall socket. It’s visible if you look at the cord. I pressed it three times with a short space between and the Fitbit restarted
Sent from my iPhone
Best Answer05-29-2019 07:52
05-29-2019 07:52
Just received fitbit Alta HR yesterday. Went through the set up and updates. The app shows a full battery. The fitbit logo and version appears for a couple seconds then goes blank. I've tried the reset steps multiple times and didn't solve the issue.
05-29-2019 13:41
05-29-2019 13:41
I had the same issue of my screen not showing anything; even while charging. It had more than half a battery, and would still vibrate and track activity (according to my app). I tried resetting it numerous times and nothing - but I just kept pushing the restart button on the charging cable until the display finally lit up. T-minus 40 min later the screen is still showing as normal 🙂
Best Answer07-11-2019 09:44
07-11-2019 09:44
I tried re booting but still no display on my Fitbit Alta HR
07-13-2019 08:05
07-13-2019 08:05
I tried the reset button several times and the screen still wont restart. Please help!
07-15-2019 07:15
07-15-2019 07:15
My Alta HR doesn't vibrate when I attach it to the charger (so I can't restart it). Screen is blank; it would only sync when I removed it from the charger (when it still charged).
Best Answer07-21-2019 16:20
07-21-2019 16:20
Hi. My Alta HR battery was dead and so I charged it. When I put it on my wrist, I don't see the green light and I tap the screen but it is blank. I put it back on the charger and tried to restart per previous instructions, but it just shows the battery and then scrolls "www.fitbit.com/setup." It's also not syncing. I have had it a year.
Best Answer07-21-2019 22:12
07-21-2019 22:12
I am having the same issue, but the day it stopped working, the display would light up, but it looked like jibberish, then went blank. Still tracking steps and synced to phone. Tried restarting multiple times with no display activity.
Best Answer07-22-2019 00:28 - last edited on 10-10-2019 16:54 by LiliyaFitbit
I am having the same problem!
Kind regards,
Best Answer07-26-2019 23:00
07-26-2019 23:00
Mine is doing the same on and off wrist and it also will not show the Fitbit logo it also will not show its charge.
