11-21-2018
03:27
20:08
11-21-2018
03:27
20:08
Hi,
This morning my screen has decided it doesn't want to display anything when I tap or swipe it. My battery is half charged and I have tried doing a reset of my tracker but to no avail.
Thanks
Moderator edit: Updated title for clarity
09-22-2019 09:17
09-22-2019 09:17
I have tried everything from switching of the app and re opening, restarted iPhone and iPad. Switched off blue tooth and re booted. And held the button 4 times in 10 seconds.
The battery is over 50% full, when I press the button on the charger the battery mark is solid and it does vibrate.
Disconnect the charger and a message to reset and web page details. On the app it is showing the steps I have achieved. Screen remains blank?
09-22-2019 16:56
09-22-2019 16:56
18:20
04:15
JuanJoFitbit
09-22-2019
18:20
04:15
JuanJoFitbit
I tried rebooting to have display work and no luck. Very disappointed as my Fitbit is only 1 year old.
hi what was your other brand that lasted 28 days I am definitely interested.
Moderator edit: merged reply
09-22-2019 19:50
09-22-2019 19:50
09-23-2019 16:14
09-23-2019 16:14
Best Answer09-23-2019 17:59
09-23-2019 17:59
Hello! I am having the same issue, but I’ve tried the restart and the screen remains blank with no response.
09-26-2019 05:35
09-26-2019 05:35
Had the same problem occur yesterday. Tracker just turned off at some point while I was wearing it. Still had some life on the battery, but wouldn't recharge when I attached it to the power source. Attempted to do the restart, no luck. Finally tried to restart it following your *specific* instructions to do the 3 presses *within 4 seconds* - screen came back on, and tracker started to recharge. I hope and assume that it will be back to normal once the battery has reached a full charge. Thank you!
10-16-2019 17:26
10-16-2019 17:26
My Fitbit did not respond after the three presses on charger. Please advise.
11-03-2019 18:11
11-03-2019 18:11
Fitbit said my inspire was unrepairable after troubleshooting. Was advised to just buy a new one. 😞 i think this is planned obsolescence.
11-04-2019
12:10
04:17
JuanJoFitbit
11-04-2019
12:10
04:17
JuanJoFitbit
i got the same answer for my alta hr with a blank screen.
im having the same problem i think it has something to do with an update it was working fine and now all of a sudden couple weeks ago i have no screen everything works but no screen and fitbit says its run its course to buy a new one.
12-07-2019 12:29
12-07-2019 12:29
I had the same problem, however when I am trying to restart my fitbit, it does not vibrate and restart.
What should I do?
Thank You,
Rhythm
Best Answer12-14-2019 06:43
12-14-2019 06:43
Best Answer12-20-2019 01:15
12-20-2019 01:15
My fit bit Alta HR screen is still not turning on. I can sync it and I can charge it but the screen isn’t working
Best Answer01-04-2020 15:09
01-04-2020 15:09
My Alta HR just died yesterday. Battery has not been holding charge. I have reset it 3x and recharged it fully, but within one hour of the reset and new charge, the fitbit goes blank and is dead again. I have owned this ALTA HR for quite a while, at least 4 years, since they first came out and I really like it. Looks like I will have to get a new FITBIT unless someone has ideas.
Best Answer01-04-2020 15:13
01-04-2020 15:13
01-07-2020 01:54
01-07-2020 01:54
Hello
My fitbit alta hr is fully charged however display not showing. When on the charge unit I can get the different screens to flash up but only briefly. I have attempted the reset & I have seen the fitbit logo flash up but then it goes to flashing between full battery image & logo, sometimes the home screen (time) flashes up. If I take it off the charger it stays with the battery image & if I tap the screen it sometimes flashes through the screens. It was fine one day then appeared to 'die' while on charge.
Best Answer01-09-2020 12:03
01-09-2020 12:03
The reality of these devices is that they last a bit over a year, then they die.These things have the endurance of an asthmatic tortoise running a marathon.
If they cause trouble within a year then customer service will send you a new one most likely, but if they are more than 1 year old and they go wrong then you are ON YOUR OWN.
Factor that into your purchasing decisions when you decide to but a fitness tracker.
01-16-2020 05:31
01-16-2020 05:31
I tried this. The Fitbit logo appears then disappears. The screen is still blank. I have tried this several times and the screen is still blank. Are there any other suggestions?
Best Answer01-16-2020 11:54
01-16-2020 11:54
I follow the instruction to reboot my watch but when I click on the side button I see wavy lines for 1 second and then blank. The watch is still recording my movements just no display. I could not find any other instruction for this situation. I activated the watch 1/25/2019.
Where do I go from here?
Best Answer01-17-2020 04:04
01-17-2020 04:04
I was setting up my Ultra Hr that I bought 6 months ago. I charged for about 4 hours and did set-up. Nothing at all slowed on display. I was able to sync on app and got to code to enter from display, but nothing shows on display. It vibrated when I connected charger and also when I try to reset.
