11-21-2018 03:27 - last edited on 08-20-2020 20:08 by MatthewFitbit
Hi,
This morning my screen has decided it doesn't want to display anything when I tap or swipe it. My battery is half charged and I have tried doing a reset of my tracker but to no avail.
Thanks
Moderator edit: Updated title for clarity
07-02-2020 06:38
07-02-2020 06:38
07-02-2020 07:42
07-02-2020 07:42
07-02-2020 07:44
07-02-2020 08:17
07-02-2020 08:17
07-03-2020 10:24
07-03-2020 10:24
07-03-2020 17:05
07-03-2020 17:05
Neither my wife nor I have been able to 'synch' our Fitbits (Alta HRs) to the PC apps. My last successful synch was at 9:27PM on July 2, 2020. The apps indicate 'synching' or "locating tracker" but never change any of the indicators normally received from the Fitbit ... only the 'guesstimates' of the number of calories, etc.
Has Fitbit discontinued support for the Alta HR?
07-03-2020 17:39
07-03-2020 17:39
07-03-2020 22:01
07-03-2020 22:01
07-04-2020 23:51
07-04-2020 23:51
My Alta hr just went blank. Last time it sync was maybe around 7 pm july 4,2020. My phone says refreshing then no device found. My Fitbit is more than 2 years old. I attached it to the charger again, it has display again for a while and the green lights underneath are always on.
07-05-2020 06:20
07-05-2020 06:20
07-05-2020 06:48
07-05-2020 06:48
07-05-2020 08:40
07-05-2020 08:40
07-05-2020 10:59
07-05-2020 10:59
07-05-2020 13:47
07-05-2020 13:47
07-05-2020 16:09
07-05-2020 16:09
I am having this exact same issue. I contacted customer support on 6/30 because I was having a problem with the silent alarm failing to work periodically (every thing else worked perfectly). The customer service rep pointed out that he could see I had an update outstanding, so of course, I update my app and now the device just shows a blank screen and doesn’t work at all. I feel like I’m being scammed because of course my Fitbit is outside warranty and conveniently they’ve given me 25% off to get a new device before rendering the one I have completely useless with their update or by customer service, who knows. I can’t even get an Alta HR anymore.
07-05-2020 17:42
07-05-2020 17:42
07-05-2020 17:53
07-05-2020 17:53
07-05-2020 17:54
07-05-2020 17:54
07-05-2020 20:11
07-05-2020 20:11
07-06-2020 16:09
07-06-2020 16:09
Great tips! I didn’t even know there was a reset button until I read this thread. Haha
unfortunately, pressing the reset three times does not work. I have also tried holding the button for 15 seconds. Disconnecting. And reconnecting. Nothing seems to work. Screen is still black. Any tips? Or do we think it died?
thanks!
