11-21-2018
03:27
20:08
11-21-2018
03:27
20:08
Hi,
This morning my screen has decided it doesn't want to display anything when I tap or swipe it. My battery is half charged and I have tried doing a reset of my tracker but to no avail.
Thanks
Moderator edit: Updated title for clarity
07-06-2020 16:20
07-06-2020 16:20
Best Answer07-07-2020 00:06
07-07-2020 00:06
Best Answer07-07-2020 04:22
07-07-2020 04:22
That’s great @Billy-Pud! I really don’t think that there will be a patch for the app that fixes the issue, especially since Alta is being phased out.
Best Answer07-08-2020 19:57
07-08-2020 19:57
I’m having the same issue and I tried all of the instructions and tips and nothing is working. It won’t reboot and nothing displays on the screen.
can you help me?
Thank you 🙏🏼
Best Answer07-08-2020 20:01
07-08-2020 20:01
I had no luck. I talked to support and they gave me a discount code to buy a new one.
Best Answer07-08-2020 20:03
07-08-2020 20:03
07-08-2020 20:13
07-08-2020 20:13
07-08-2020 21:07
07-08-2020 21:07
Best Answer07-08-2020 21:11
07-08-2020 21:11
Best Answer07-08-2020 21:26
07-08-2020 21:26
Best Answer07-09-2020 01:15
07-09-2020 01:15
Best Answer07-09-2020 01:22
07-09-2020 01:22
Best Answer07-09-2020 02:04
07-09-2020 02:04
Best Answer07-09-2020 07:47
07-09-2020 07:47
Mine was not under warranty anymore. That’s why they gave me 25% off code.
Best Answer07-09-2020 09:28
07-09-2020 09:28
Best Answer07-09-2020 10:16
07-09-2020 10:16
Best Answer07-09-2020 10:31
07-09-2020 10:31
Best Answer07-09-2020 13:57
07-09-2020 13:57
Best Answer07-09-2020 23:40
07-09-2020 23:40
Best Answer07-10-2020 11:46
07-10-2020 11:46
Alta screen is blank. I tried to reset my Fitbit but screen remains blank?
