Alta HR display won't turn on
My display on Alta is not visible. Can this be fixed ?
1 REPLY 1
Hi @Craggy  you can try a restart of the device, but it probably won't help. I had the Alta HR and over time the screen was fading. I replaced it with the Luxe and the screen is much brighter. Sorry there isn't much you can do.
Stepping in the U.S.A. since September 2013. Android 14
