Alta HR heart rate sensor won't work
Hi My Fitbit Alta HR heart rate sensor is not working at all. Tried all troubleshooting methods.
1. Restarted devise (3 clicks in 4 seconds method) - Performed it more than 10 Times - No Progress
2. Heart Rate mode is ON/ Auto. Tried to switch between these several times - No progress
3. Tried changing Phones & re synced devise - No Progress
4. The green light below itself is not glowing.
Please advise if there is any way it could be fixed. Its less than 2 years old - Well maintained devise.
1 REPLY 1
Welcome to the Forums, @sheelas.
Thanks for troubleshooting this heart rate sensor issue. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
In the meantime, let me know if you need anything else.
